Constant clogging
Seite 1 / 2
Atle Dreier
(@atle-dreier)
Constant clogging
prebuilt Core One, a few weeks old, 5-6 days total print time.
After a rough period of initial issues, it's now unuseable.
0.4mmHF nozzle that came with the printer. It clogged a few times in the beginning. I blamed the filament, so bought a dryer, built a drybox, and discarded a lot of prints. Occasionally it printed acceptable prints, but sometimes clogged for no reason I could see.
The last few days I can't print more than a few minutes before it invariably clogs up.
So, idler and extruder gear looks fine. Clean, no debris.
Nozzle looks fine to me. I've had it out, the filament goes through about to the threaded bit. Needle goes through easily after heating and prodding it for a bit.
Looking at print history, the temps seem fine, it's holding steady at the preset temp, and fan speeds look normal, as far as I can tell.
Using Prusament and other filaments, no discernible difference.
At this point, my new printer is broken. Any tips to how to fix it, besides changing the nozzle and hoping it doesn't happen again?
Veröffentlicht : 20/10/2025 6:31 pm
RE: Constant clogging
What kind of filament are you using with that nozzle? Are you sure it's a clog and not the idler being too loose and not gripping the filament?
Veröffentlicht : 20/10/2025 11:50 pm
Atle Dreier
(@atle-dreier)
Not the idler, I can't push through even with pliers and 290 degrees nozzle.
I've tried different filaments, it happens with bone dry Prusament too.
Current theory is that the clog is above the heatbreak. I'll try a heatgun and see if I can get it clean.
Veröffentlicht : 21/10/2025 2:21 pm
Use a scrap of pale coloured filament.
Open the idler and push the scrap down as far as it will go - mark the filament at that point (sharpie) then pull it out and offer it up against the outside; this will show where the blockage starts.
Veröffentlicht : 21/10/2025 4:02 pm
Artur5
(@artur5)
Do yourself a favor and replace that HF nozzle with a normal NON  HF nozzle.
Veröffentlicht : 21/10/2025 5:40 pm
Posted by: @artur5
I use HF nozzles with most standard filament types and have yet to experience a clog. Of course I keep all my filaments in dry boxes and the super hydroscopic ones (like PA) I print from the dryer. The NON HF nozzles I use for things like wood, silk, CF and GF. So both have their place. Depending on the print volume and material I can get a substantial savings on print times with a HF nozzle. What is interesting is that for some types prints and filament types, estimated times for non-HF nozzles can be faster.
Veröffentlicht : 21/10/2025 5:55 pm
gb160
(@gb160)
I use a hf nozzle and only ever get clogs when using PLA with the door closed.
Veröffentlicht : 21/10/2025 7:38 pm
Posted by: @gb160
That's interesting. I remember I read somewhere that Prusa recommended leaving the door open for running PLA with the 0.4mm HF nozzle. Of course the door sensor has to be off for that to work so I probably misread it.
The only PLA I've printed recently is the smelly Prusa rPLA: Wine, Algae, Corn and Rice filaments (which are kind of cool BTW) and some wood fill. I definitely don't use a HF nozzle for those however.
Veröffentlicht : 21/10/2025 7:53 pm
gb160
(@gb160)
Yea I think the heartbreak fan can’t keep the temp low enough causing clogs. I use Matte Overture PLA  a fair bit and the recommended temps are a bit lower than most PLAs so I think that exacerbates the issue for me.
Ive set an alert via custom gcode which shouts at me if im printing PLA to open the door 🤣
If you’ve got any kind of DIY filtration stuck on the back then you have to ramp the exhaust fans a fair bit for the same reason.
Veröffentlicht : 21/10/2025 8:06 pm
Posted by: @gb160
I converted a toaster oven into a PID controlled SMD reflow oven that I also use filament annealing. It has a servo that partially opens and closes the door.
I just picked up the GPIO module and have been looking for a project to make use of it. Maybe an automatic door opener. Well it won't open it all the way, maybe just prop it open 3 or 4 cm. Perhaps extend it to the top vent as well (although I did see something already on Printables for the same).
Veröffentlicht : 21/10/2025 8:50 pm
Atle Dreier
(@atle-dreier)
Got one yesterday afternoon, printed a few items perfectly.
I'll keep at it, and see if I can unclog the HF nozzle manually.
Posted by: @artur5
Veröffentlicht : 22/10/2025 11:27 am
Atle Dreier
(@atle-dreier)
Interesting. That's a heatbreak cooling issue then? My cabinet temp is hardly ever over 27C, but I'l lstart monitoring the heatbreak temp to see where I'm at.
I'm sometimes door open, sometimes shut, I haven't though that made any difference, and the cabinet fans would kick in if needed.
Posted by: @gb160
Veröffentlicht : 22/10/2025 11:28 am
TomK
 TomK
(@tomk-2)
Mitglied
I had the same problem and I concluded that one or more of the 4 channels in the high-speed assembly with the HF nozzle from PRUSI is clogged so that it cannot be cleaned or melted. The probable contamination is of a mechanical nature (a burr, a splinter from processing the brass nozzle?). I fixed it this way: I installed the adapter from PRUSI and the HF nozzle from another supplier (3 internal channels). Problem solved. I print on the HF profile perfectly like with the original.Try this method too, maybe it will solve your problems.
Veröffentlicht : 23/10/2025 2:30 pm
gb160
(@gb160)
Posted by: @atle-dreier
Posted by: @gb160
It's an easy thing to rule out mate. Try printing with the door open and see if it makes a difference.
Might be worth putting the heatbreak temp on the Home Screen, then see what that reads when you next get a clog.
Veröffentlicht : 23/10/2025 9:47 pm
Atle Dreier
(@atle-dreier)
Posted by: @gb160
Posted by: @gb160
Cabinet temp is 27, HB temp is 36 after an hour of printing. Seems to have stabilized there. Seems will within range?
Door open I get 24/31.
Veröffentlicht : 24/10/2025 5:44 am
gb160
(@gb160)
Posted by: @gb160
Posted by: @gb160
It seems fine, the proof is in the pudding though:
Do the clogs stop with the door open ?
Veröffentlicht : 25/10/2025 10:35 am
Atle Dreier
(@atle-dreier)
No, they never stopped.
Sent the printer back, they changed the entire hotend. I have an hour of printing on it, just had it returned. Printing great for now. We'll see.
Door open or closed never seemed to make a difference.
Posted by: @gb160
Posted by: @gb160
Posted by: @gb160
Veröffentlicht : 24/11/2025 7:31 pm
Ed
 Ed
(@ed)
I have the same exact issue with my new Core One L (same Nextruder, also CHT nozzle factory-installed). Prusament PETG, prints beautifully on my Mini but clogs on the C1L with CHT nozzle - reproducible. Purchased a filament dryer - no difference. Unload/Load/Purge - no difference. Cold Pull - no difference.
Support asked me to heat to 270C and use acupuncture needle - nothing. At that point I gave up and changed to the included hardened nozzle so I could at least start using my brand new printer.
No problems anymore since I switched to the “normal” nozzle. Not sure what the cause is, but CHT seems a lot more susceptible to clogging.
Veröffentlicht : 24/11/2025 8:18 pm
Tim
 Tim
(@tim-21)
Mitglied
When you decide to poke a needly up into the nozzle, remember the nozzle isn't straight thru like a normal flow nozzle. Inside the nozzle are channels and your needle may well damage the HF nozzle interior.
https://www.reddit.com/r/prusa3d/comments/1h28t6a/prusa_hf_versus_prusa_cht_which_is_also_highflow/
Veröffentlicht : 26/11/2025 3:52 am
Ed
 Ed
(@ed)
Indeed - can you imagine my surprise as Prusa Support actually suggested heating the nozzle, then drilling out the clog/obstruction using a power drill with 1.5mm drill bit? (I assume they meant from the top opening)... I feel this CHT nozzle is more prone to clogging than a "standard" nozzle due to the internal structure.
I have not kept up with nozzle technology, but are these CHT nozzles a new development? Perhaps some tool marks or burrs were left in the nozzle after production?
Veröffentlicht : 26/11/2025 8:16 am
Seite 1 / 2
