Clicking noise coming from extruder unable to print
37VI5
(@37vi5)
Miembro
Clicking noise coming from extruder. This started about 3 weeks ago, I have not been able to print. I've had this CORE ONE for about 5 months. The noise was very noticeable. I disassemble the extruder, cleaned the gears and put it back in place. I tuned the belt and recalibrate everything. The sound got somewhat better but it is still not printing right. Not sure if is the motor the nozzle ( which I also cleaned many times).
Respondido : 17/04/2026 1:22 am
k1mu
 k1mu
(@k1mu)
RE: Clicking noise coming from extruder unable to print
There's not enough information here to be able to help much.
What are you printing (PLA, PETG, ASA ...) ?
Does your print start out OK then you're getting an extruder jam after some time (which usually means that the heat break temp is too high)?
Or does it never feed any filament at all (which usually means a clogged nozzle, calling for a cold pull)?
Respondido : 19/04/2026 1:06 pm
