Can you use Layerneer on a Satin Print Sheet using PLA
[Resuelto] Can you use Layerneer on a Satin Print Sheet using PLA
Página 1 / 2
Giorgio1!
(@giorgio1)
I plan on printing with PLA, I bought a sating sheet to go with my Prusa CORE One. I heard that your supposed to use bed adhesive when printing sometimes to help the print sitck.
My Question is:
Can you use Layerneer Bed Adhesive on a Satin Sheet when printing with PLA?
thanks!
Respondido : 10/02/2025 7:18 pm
3Delight
(@3delight)
Moderador Moderator
RE: Can you use Layerneer on a Satin Print Sheet using PLA
While I've not got a Core One, I've never had to use an adhesive when printing PLA on my MK3S+ or my MK3.5, I would wait to try without first.  If it calibrates correctly it should stick just fine.
Respondido : 10/02/2025 7:23 pm
Giorgio1!
(@giorgio1)
Can you still use Layerneer Adhesive on a satin print sheet? I'm trying to decide if I should buy it or not. People say that it is good just to keep around in case you need it.
Respondido : 10/02/2025 7:25 pm
3Delight
(@3delight)
Moderador Moderator
I don't know to be honest, as I said I've never had a problem with adhesion that couldn't be fixed by cleaning the sheet and/or lowering the Z height.
Respondido : 10/02/2025 7:39 pm
Giorgio1!
(@giorgio1)
Great, thanks for your help with this. I really appreciate the advice!
Respondido : 10/02/2025 7:43 pm
Walter Layher
(@walter-layher)
You can use glue on any kind of print sheet. I find it is better to have it on hand for tricky cases, e.g. for objects that cover the whole print sheet. I use 3d lac occasionally. It does not harm the print plate and can be washed off with hot water and/or IPA.
Respondido : 10/02/2025 8:26 pm
Giorgio1!
(@giorgio1)
do you by any chance have a link for where I can get this from?
thanks for all your help!
Respondido : 10/02/2025 8:31 pm
Giorgio1!
(@giorgio1)
Do you use the spray or the stick? also, what is the difference between 3d lac and 3d lac plus+
Respondido : 10/02/2025 8:34 pm
iftibashir
(@iftibashir)
I would try printing without glue at first - you may find you don't even need it.
Ive never used glue with any PLA prints.
Respondido : 10/02/2025 9:48 pm
1 les gusta
Taubin
(@taubin)
You could always try a standard glue stick first. I'm not sure how much the Layerneer costs, but I bet a standard glue stick would be much cheaper and probably work about as well.
Respondido : 10/02/2025 10:18 pm
Giorgio1!
(@giorgio1)
thanks, I'll try that!
Respondido : 10/02/2025 10:23 pm
Walter Layher
(@walter-layher)
I have mostly used the brand "3d lac plus" in spray bottles that work with an air pump, without aerosol. It is available on Amazon or on shops that sell filament.
If you need it or not is also dependent on the filament brand sometimes. I have printed the same model without needing adhesive at all with one brand of PLA and then changed to another brand of PLA where the corners lifted off the plate. I sprayed the corners of the print sheet with 3d lac and the next print was okay.
And concerning the price: one big print that needs about half of a spool, fails, and has to be printed again will cost a lot more than the 3d lac that was used to make one successful print.
Respondido : 10/02/2025 10:28 pm
That advice is ten years out of date.  These days unless you are using high-tech specialist filaments all glues are used to *reduce* adhesion.  You will never need it for PLA on a modern print sheet.  If PLA won't stick, wash the print sheet.
Respondido : 11/02/2025 12:05 am
1 les gusta
iftibashir
(@iftibashir)
Posted by: @diem
The wise man has spoken!!!
100% agree
Respondido : 11/02/2025 7:58 am
LarGriff
(@largriff)
That “up-to-date advice” has not been true, in my experience.  I print mostly PLA and have tried all 3 (smooth, satin, textured) build plates, washed with soap & water and/or IPA90, with and without adhesive (Magigoo) and they always stick best with Magigoo.  PETG, for me, won’t even barely stick to my smooth sheet without adhesive yet that’s the combination that everyone warns will stick so firmly it damages the plate.  For me, it just curls right off.  I dry my filament, too, generally printing straight from the dryer box.  I dab a few spots of Magigoo on the clean plate, then spread it around evenly with a moist microfiber cloth.  YMMV.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 11/02/2025 9:03 am
iftibashir
(@iftibashir)
Thats strange - I always print straight on the smooth sheet and have never had any issues at all. I never touch the bed other then from the very edges, so haven't actually washed or cleaned it in absolutely ages - just give it a quick visual to ensure there's no marks or finger oils etc on it, sometimes the odd spray of IPA, and off I go. I've never had a print come loose on the MK4s, ever........let's hope I don't jinx myself though!!! lol
Respondido : 11/02/2025 10:50 am
2 les gusta
It might have to do with the room temperature? My printer lives in the basement, which gets chilly in winter, and I have seen bed adhesion issues with PLA and PETG when the room temperature is about 15°C or less. One of the reasons why I am looking forward to the Core One with its enclosed chamber!
Respondido : 11/02/2025 11:08 am
1 les gusta
Some new print-sheets don't begin to adhere properly until they have been thoroughly scrubbed.
Respondido : 11/02/2025 12:34 pm
Giorgio1!
(@giorgio1)
when you get a new print sheet, should you wash it with soap first so it can adhere properly?
Respondido : 11/02/2025 12:39 pm
From P6 of the Core One manual:
Operating Temperature Range: 18 °C - 38 °C
Respondido : 11/02/2025 12:50 pm
Página 1 / 2
