Can not get Buddy3D to connect
GaryBushey
(@garybushey)
I have the Buddy3D for the Prusa Core One but it never seems to register.  It connects to the network and did a firmware update on its own.   Now, when I follow the instructions to create the QR Code and press the reset the button the camera states that it is looking for the QR Code, Finds the QR Code, and stops looking for the QR Code but it never shows up in Prusa connect as being connected.   Any ideas?
Respondido : 22/01/2026 11:34 pm
jan.d.slay
(@jan-d-slay)
RE: Can not get Buddy3D to connect
How many times did you try? I had to try five times before it finally worked.
Respondido : 23/01/2026 11:54 am
GaryBushey
(@garybushey)
I've probably tried about a dozen times so far.  Will keep trying
Respondido : 23/01/2026 12:06 pm
jan.d.slay
(@jan-d-slay)
Please don't misunderstand, but it's part of the process:
Has the rubber cap at the front been removed?
But I think you've seen that.
Respondido : 23/01/2026 12:09 pm
GaryBushey
(@garybushey)
Don't worry about it.  I have done enough stuff like that in my time 🙂   But, in this case, I do have the cover off.
Respondido : 23/01/2026 12:49 pm
1 les gusta
jan.d.slay
(@jan-d-slay)
No problem. I'm glad you're taking it in stride. In my last job, if the error simply couldn't be found, the rule was: back to the beginning!
Okay, so... the only thing I can think of is to increase or decrease the distance between the QR code and the camera lens, and maybe increase the display brightness.
Respondido : 23/01/2026 2:09 pm
GaryBushey
(@garybushey)
It says it finds the QR code just fine.  But once it does, I never see it in Prusa Connect
Respondido : 23/01/2026 2:22 pm
GaryBushey
(@garybushey)
So I just checked again and it appears to be working.  Very weird.
Respondido : 23/01/2026 7:37 pm
1 les gusta
jan.d.slay
(@jan-d-slay)
Posted by: @garybushey
I suspect that it was Prusa Direct or their connection. In the last few days, I also had difficulties connecting to PrusaSlicer and my account. Since yesterday, everything has been working again as if nothing had happened.I think your attempt to connect to the camera falls into the same category.
Respondido : 24/01/2026 9:49 am
