Building a stand
Schnarchler
(@schnarchler)
Miembro
Building a stand
I have pre-ordered a Core One Kit. I would like to build a base for the printer before delivery. Could someone who already has the printer help me?
  • Are these dimensions (415×444×555 mm; 16.3×17.5×21.8 in (X×Y×Z)) with or without display?
  • How big are the chamfers on the edges?
  • I saw on Youtube that the bottom is open at the bottom. Where exactly are the stands positioned?
  • Has anyone already created a true-to-original CAD model? The ones I found were not satisfactory.
Many thanks and happy printing
Respondido : 23/03/2025 9:03 am
Chocki
(@chocki)
Do yourself a favour and go buy a concrete paver 400mm x 400mm and at least 40mm thick and build the stand to hold this, the printer will sit just perfect on this and you will have a much better base to deal with all the movement and vibration.
As you can see the frame sits on the paver nicely.
You could add a nice wood surround to hide the paver and even place it on sorbathane sheeting.
Esta publicación ha sido modificada el hace 12 months 2 veces por Chocki
Respondido : 23/03/2025 3:11 pm
Rainer
(@rainer-2)
RE: Building a stand
I would also like to build a stand for the Core One. But I'll wait until I've built the kit.
I also plan to use a stone slab that is also decoupled as a base.
It should be flat on top so that it is no longer visible when the printer is standing on it.
Underneath there is space for 5 filament rolls, airtight, in case the MMU3 moves from the MK4s to the Core One.
Respondido : 23/03/2025 8:10 pm
tomtim
(@tomtim)
Miembro
Hey hey, you have such a fancy designer printer and you put it on an old cobblestone? Yuck...
I had my local craftsman (he usually makes window sills) make me a marble slab with rounded edges. It looks great - the shine is easy to wipe off. The slab is on double-sided tape (about 4mm thick, so that the tape is simply stuck to the slab with the cabinet. The MK4s used to be on it and as I see today... the squash balls he also has today would have been enough.
Respondido : 23/03/2025 8:49 pm
1 les gusta
Chocki
(@chocki)
Looks good does that marble. If I can find somewhere near me that can make something like that art a reasonable price then I would buy it, the paver is more an experiment, a cheap experiment and it works really well, but I need to get the printer off the floor going forward so will see what I can get/make
Respondido : 23/03/2025 9:11 pm
1 les gusta
You should be able to get standard-size paving stones from nicer materials, and with smooth edges -- granite or other stone. 40*40 cm² used to be the standard size here, but has fallen out of fashion a bit in favor of larger formats. But can still be found, typically 4 cm thick.
Respondido : 23/03/2025 9:15 pm
1 les gusta
