Buddy 3D Camera not connecting to Wifi with $ in password
TubularNut
(@tubularnut)
The Core One (assembled) has connected to my WifI with no issues, only a few meters away from the printer.
The camera refuses to connect after multiple attempts using the app and QR code.
Setup a guest WiFi network with no $ in the password, and the camera connects on first attempt.
Is there an issue with special characters on the camera? I've had this before with other devices.
Posted : 25/04/2025 5:59 pm
Kachidoki
(@kachidoki)
RE: Buddy 3D Camera not connecting to Wifi with $ in password
Not your issue but similar, on the printer itself I am not able to use NFC when the SSID contains an accent like "é" in it, it becomes "?".
Posted : 26/04/2025 7:23 am
cejones2
(@cejones2)
It appears that special  characters and spaces are not allowed in the WIFI password with the firmware level 3.01.  It is should be fixed in level 3.04.
Posted : 26/04/2025 4:44 pm
TubularNut
(@tubularnut)
Posted by: @cejones2
Thank you, I am already on 3.04, I was hoping there was a later revision 🙁
Posted : 27/04/2025 2:11 am
