Brittle filament broke in filament tube, how do I remove tube?
5UNM0TH
(@5unm0th)
Membre
what it says on the tin. I loaded cheap, brittle filament that broke in the tube when i tried to unload it. how do I remove it?
(prusa one+)
Publié : 29/03/2026 11:25 pm
RE: Brittle filament broke in filament tube, how do I remove tube?
Remove the Bowden tube from the top of the Nextruder push some filament through on the right side, push out the broken pieces.
Publié : 30/03/2026 9:20 pm
1 personnes ont aimé
jan.d.slay
(@jan-d-slay)
(prusa one+)
That happened to me too. Unfortunately, I caused the problem myself. I usually always use PTFE tubing with a 3mm inner diameter. But when I replaced the tubing, I ended up with one that was 2mm.The filament got so tangled and jammed up that I had to throw out the entire PTFE tubing along with the filament :-DSo: Please also check if you have a PTFE tube with a larger inner diameter. Just my opinion.
Publié : 31/03/2026 5:44 am
