Belts tension way appart from each other
c10l
 c10l
(@c10l)
Membre
I've tried many times to adjust my belts so they match the recommended tension frequencies.
Unfortunately the top belt is too tight at ~107 Hz whilst the bottom one is way too low at ~82 Hz.
How can I make them get closer together? I have already taken the hotend apart and tightened the bottom belt, but when I try to adjust it, they're always that distant from each other.
Adjusting frequencies doesn't change that very much as if I don't adjust both belts simultaneously, the gantry goes out of square with the frame.
Best Answer by c10l:
Ok, seems like I figured it out. After a frustrating experience with support the other day, I decided to investigate a bit more.
My gantry was out of square at rest (with no belt tension), so it was relying on the different tensions to stay square. I fixed it by bending the gantry attachments a little by pulling one side towards me until it was square at rest.
After that, I managed to get both belt tensions right.
Publié : 25/08/2025 2:02 pm
c10l
 c10l
(@c10l)
Membre
RE: Belts tension way appart from each other
Publié : 25/08/2025 6:54 pm
1 personnes ont aimé
Marky
(@marky)
Membre
Hey, I'm curious on how you did this, but with more details? Are you talking about the linear holders when you're mentioning the gantry attachments? and did you basically unscrew the tensioning screws to get the rest state of the gantry?
I'm new to the terminologies, that's why I'm asking.. I'm having some issues with the Y-axis "slipping" when printing. And when I've tensioned the belts, there seems to be a little play on the Y axis.
Publié : 01/09/2025 8:34 am
Chris Hill
(@chris-hill)
Posted by: @marky
I don't recall where I saw Prusa's description of this process for getting the gantry square initially, if indeed I did, but I described it here: https://forum.prusa3d.com/forum/postid/760836/
Publié : 01/09/2025 10:38 am
c10l
 c10l
(@c10l)
Membre
That describes what I did (and a bit more!) in much better detail than I could myself. Thanks!
I just wish Prusa would put that explanation in the assembly and maintenance guides, and that I'd found it before I pulled my hair out trying to get the tension right.
The guide actually tells you to do the wrong thing - to make it square by increasing tension on the side that has the most slack. That throws the tension balance completely out of whack though.
Publié : 01/09/2025 11:13 am
Chris Hill
(@chris-hill)
Posted by: @c10l
Yes, that's always puzzled me.  Maybe they're assuming the gap is very small, so the necessary imbalance in the tension is correspondingly small.  If that's the case then they should say so IMO.
Publié : 01/09/2025 1:11 pm
