Beltrouting is causing VFA ?
Stránka 1 / 3
Ckobar
(@ckobar)
Hi there,  since the core one is my first core-xy-printer.....
  Looking at the meanics of the belt-routing i wonder, if this might cause some inaccuracies.
For exsample: When the belt puls the linear-rail back, the "force" of the y-belt is applied to the pulley on the left side of the linear-rail , if it moves forward  the "pulling -force" is applied on the other side of the linear-rail .
Since its has been discussed elsewere, that the linear-holdes are quite flexible. I wonder if this flex is transfered to the linear rail during printig. ?
But maybe i`m wrong ?  Thanks for your input 🙂
Napsal : 14/05/2025 10:12 am
Belt ripple is observed while the print head moves linearly, at constant speed -- i.e. in the absence of direction changes or accelerations. So I don't think deformations of the drive train due to dynamic load changes play a big role with belt ripple.
The general assumption is that it is linked to the belt teeth, although it is unclear what the exact mechanism is. It might have to do with teeth rubbing on the flanges of the idlers; or with the toothed side of the belt running over smooth idler wheels (in two locations); or the different elasticity/hardness of the teeth vs. the gap regions of the belt. Motion that is uneven on a microscopic scale, due to imperfect micro-stepping of the motors, might also have an effect.
Users have tried various fixes, in the Core One and other printers before it. The only consistent observation seems to be that there are always some printer units where a particular fix has helped, and others where it has no effect at all.
Napsal : 14/05/2025 11:01 am
1 lidem se líbí
ticric
(@ticric)
Hi everyone, I’m about to build my core one in the next week and was thinking at replacing the 2 smooth idler where the tooth of the belt is rubbing with 2 toothed idler,I don’t know if it’s a good idea.I have made that on my mk4s on the bed axis and saw an improvement.I want to know if  anyone have try this on his core one? Thanks!
Napsal : 18/05/2025 12:31 pm
RE: Beltrouting is causing VFA ?
Posted by: @ticric
@altaic and @brian-12 have looked into this here, but I am not sure whether one of them has already tried the modification. Seems that no direct drop-in replacement part was found, but that the mounting blocks for the idlers need some adaptation to make things fit.
Napsal : 19/05/2025 9:28 am
2 lidem se líbí
ticric
(@ticric)
Thanks I will follow that!!
Napsal : 19/05/2025 11:07 am
Brian
(@brian-12)
I am still planning on installing them on my Core One anyways because I bought them at the same time as I bought them for my XL.  I have already altered the cad for the gantry pieces and will just need install then whenever I get the printer.  I'm sure they won't change anything but I'll do it anyways as I know it won't hurt and it can eliminate the question for others.
Napsal : 19/05/2025 11:42 pm
5 lidem se líbí
Krzysztof Papuga
(@krzysztof-papuga)
Here it is shown that someone has already done it and writes that it has been fixed by VFA
https://www.facebook.com/share/p/16Qs7ncy5R/
Napsal : 06/06/2025 5:18 am
iftibashir
(@iftibashir)
What did they say - its a private group so cannot see the post.....
Posted by: @krzysztof-papuga
Napsal : 06/06/2025 9:21 am
2 lidem se líbí
rinkel
(@rinkel)
I have done this modification, toothed idlers. I can tell you: no changes at all, nothing.
Napsal : 08/06/2025 2:52 pm
4 lidem se líbí
Chocki
(@chocki)
I'm wondering if it's the actual belts themselves, the stretch on mine in just a few weeks of light use makes me think these are not Gates belts, rather a cheap no name brand from Ali
Napsal : 09/06/2025 11:58 am
Posted by: @chocki
Hmm -- they don't have any print on the back, which I think the original Gates belts have?
Seeing that Prusa have moved to cheaper motors and Y bearings, and make their own idler wheels (which can apparently be improved upon by buying brand-name replacements), it would not come as a surprise that they try to save money on the belts as well. They must be in a tough position: Prusa's use of brand-name parts used to be one of their differentiators over the cheap Chinese competition. But with the competitors having caught up in terms of innvovation, performance and print quality, apparently the price pressure is so high that Prusa now switch to no-name parts as well.
The THK-made X rail is the only branded component I have found in my Core One kit, electronics parts aside.
Napsal : 09/06/2025 12:44 pm
Ckobar
(@ckobar)
Just checked on my Mk4.  It’s an Gates belt. If the core one belts not gates ones, it would be interesting if replacing them does make a difference?
does anybody know what length the xy bets of the core are?
Napsal : 09/06/2025 1:33 pm
Ckobar
(@ckobar)
Btw. How to distinguish between cheap and „good“ idlers ?
Napsal : 09/06/2025 2:15 pm
Posted by: @ckobar
I misspoke when I mentioned idlers, sorry -- I meant the pulleys (toothed drive gears on the X/Y motors). Switching to branded ones has been found to reduce belt ripple significantly.
I don't think the parts themselves are marked, but it is "known" that Prusa make their own. I once stumbled upon a Prusa drawing for what they called a "Prulley" -- pun alert -- but can't find that anymore.
Napsal : 09/06/2025 2:28 pm
1 lidem se líbí
gb160
(@gb160)
Its weird, I could've sworn my Core One had Gates belts...Ive definitely seen Gates somewhere in the last few days, after reading your post I was so sure I went to double check before replying...lo and behold no Gates writing on my belts.
Napsal : 09/06/2025 4:27 pm
1 lidem se líbí
Chris Hill
(@chris-hill)
My CORE One kit has Gates belts.  Batch 1, dispatched April 9th.
Napsal : 09/06/2025 4:37 pm
3 lidem se líbí
Posted by: @chris-hill
How do you recognize them? Mine is a kit from batch 1 too, dispatched a bit earlier, and I do not see any markings on the back of the belts.
Napsal : 09/06/2025 4:53 pm
Hang on, it does say Gates(R) Powergrip! On the upper belt directly to the left of the Nextruder, i.e. in a section where the back has never touched an idler. Does the print wear off quickly when the belt runs over the idlers maybe?
Napsal : 09/06/2025 5:00 pm
gb160
(@gb160)
Posted by: @jurgen-7
Yeah that makes sense...thats where I saw it.
Napsal : 09/06/2025 5:04 pm
Chris Hill
(@chris-hill)
I don't think that's it - on mine the printing is visible on the two belts at the back between the motors.  I'm pretty sure those bits regularly run over the idlers.
Napsal : 09/06/2025 5:11 pm
Stránka 1 / 3
