Belt Tensioning and Tuning New Build
Michael Kuran
(@michael-kuran)
I just built the machine a week or so ago and got it somewhere close but just can't get a grip on this part of the process.
Has anyone put together a PDF or Video that walks you through the whole process? I've read the Adjusting belt tension article on Prusa web page under printer troubleshooting. But some say use your phone to tune the belts and some say it don't work. I don't understand what the frequency setup in the belt tuning wizard and how to use it. I was wondering if anyone has done a video that covers this subject and what problems might come up and how to fix them. Any help would be great.
Mike
Respondido : 10/03/2026 12:12 pm
Same Old Shane
(@same-old-shane)
Miembro Admin
Ok, this is going to sound like a dumb question, but have you tried the tuning section in the prusa app yet?
Yes for some there was problems with the app, but opening the tuning page up directly on their phone and activating their microphone on the phone for it was a work around.
https://belt.connect.prusa3d.com/
On CORE One, the ideal target frequency range is a maximum of 98 Hz for the upper belt and a minimum of 90 Hz for the lower belt.
BUT there is a video showing the stereoscope tuning that removes the need for the app all together so you can tune the belt directly off the machine. You just have to make sure you are on the latest firmware version, and the steps are shown here.
https://www.youtube.com/shorts/8Y1dBDtqeYE?feature=share
Shane (AKA FromPrusa)
Respondido : 10/03/2026 4:13 pm
1 les gusta
Michael Kuran
(@michael-kuran)
RE: Belt Tensioning and Tuning New Build
Yes I’ve tried that and I think I’m close but when printing in some situations it makes more or a labored sound than normal. I did just find a video where the guy used the belt tuning wizard but what he did was adjust the frequency he want for the top belt and he played with the adjustment screw till he got the most throw out of the belt and did the same on the bottom. After he finished the belts were within a few hz of each other and he showed how quiet it ran.
When I get home I’ll check the video you posted and will go from there. Thank you for taking the time to reply!!!
Mike
Respondido : 10/03/2026 5:10 pm
