Bad Vibrations
Page 5 / 8
Scott
(@scott-18)
RE: Bad Vibrations
Yes it’s hard to catch on camera as the mic doesn’t catch every sound at the same level. In real life it’s really bad resonance noises.
The motor noises don’t bother me, and believe me I know what I’m talking about when I said it’s not « normal » sounds from a good printer.
Posted : 23/03/2025 6:57 am
Butter Pockets
(@butter-pockets)
RE: Bad Vibrations
I gotcha - yeah I do understand what you mean and its good to know the video didn't quite pick it up. I have heard some pretty loud resonance noises out of my Core One and other printers. My MK4 was very bad about it until I learned that a single bolt on the bed was loose and it dramatically lowered the noise of my first layer.
Posted : 23/03/2025 6:58 am
Scott
(@scott-18)
RE: Bad Vibrations
Here are other examples: https://imgur.com/a/Hs0jhml
On the first video it happened on the 60° angle back left.
On the videos with small red cube it happened on the internal perimeter (80mm/s)
On the 2 others with my SnapBack wall mount it’s on the big round external perimeter.
I don’t know if you can hear resonance noises.
Posted : 23/03/2025 7:09 am
Rolf
 Rolf
(@rolf-7)
RE: Bad Vibrations
Hi guys,
what do you think about this one?
https://we.tl/t-OFC9LcBeaq
I measured over 71dB while he yelled at me instead of regular 45-55db.
Posted : 24/03/2025 10:16 pm
Scott
(@scott-18)
RE: Bad Vibrations
Can you host the video on imgur.com instead of Wetransfer please? It will be easier for everyone to watch it. 🙂
Posted by: @rolf-7
Hi guys,
Posted : 25/03/2025 7:13 am
Rolf
 Rolf
(@rolf-7)
RE: Bad Vibrations
https://imgur.com/a/0AoYISq
Posted by: @rolf-7
Hi guys,
Posted : 25/03/2025 7:38 am
MiLkiE
(@milkie)
RE: Bad Vibrations
I measured mine at 53dB and 63dB when making the loud vibration noises, my phone was placed in front of the screen on a cloth. When I spoke with Prusa support they said this was normal, they were not concerened with the loud vibration noises.
I found reducing the speed to 85-93% seemed to reduce the noises a lot, but this seemed to be dependant on the model shape.
Posted by: @rolf-7
Hi guys,
Posted : 26/03/2025 10:21 am
Rolf
 Rolf
(@rolf-7)
RE: Bad Vibrations
That is the opposite of what I experience. The print from the video was printed with the 0.20 Structural / generic PETG profile and the speed was reduced to 90% on the printer. If I print significantly faster >150% or even <50% slower then it becomes quieter.
The model only has an influence here to the extent that only certain movements (direction/speed) of the print head trigger the loud noises.
Unfortunately i'm still waiting for a reply from Prusa support.
Posted by: @milkie
Posted by: @rolf-7
Hi guys,
Posted : 26/03/2025 11:37 am
Scott
(@scott-18)
Yep it's just a matter of specific speeds (so frequencies) of each axis that enter in resonance with the all printer or at least part of it.
In theory phase stepping should correct that by avoiding those speeds/frequencies.
So yes, changing speed will also change frequency and may help to avoid the bad once, but it's extremely dependent on the object you print (shape, linear speeds involved etc). For example, reducing speed to 90% may work for a specific print, but may trigger the bad speeds/frequencies on another.
Posted : 26/03/2025 2:44 pm
colemine
(@colemine)
RE: Bad Vibrations
I also experience the bad loud vibrations.  I mentioned it right away in a facebook group and got the ... internet shrug/gaslighting..   I adjusted/tuned my belts and run the machine at stealth mode and that has helped some.  I am waiting for the firmware upgrade before I adventure into adding sound deadening to panels.  I too found the noise so loud to the point I almost didn't want to use the printer.   I'm glad I am not alone.   Look forward to the eventual fix.  After hearing the XL was the same I am not going to stress about it.
Posted : 26/03/2025 7:59 pm
Rolf
 Rolf
(@rolf-7)
RE: Bad Vibrations
As I was not inclined to partially dismantle the printer for further troubleshooting, I decided to return it. If I had wanted to tinker, I would have pre-ordered the kit.
Basically, I'm very happy with the printer but I can't accept the noise. Unfortunately, the out of the box experience and the much praised support did not satisfy my expectations. It was good to get a choice between repair and refund, I would have chosen the repair but the expected waiting time (few weeks) was too long for me.
So maybe I'll give the Core One a second chance in the near future.
Posted : 01/04/2025 6:36 pm
Martin S.
(@martin-s-3)
We got one as well and it does vibrate a bit but then nothing compared to the XL we have.
Posted : 01/04/2025 6:47 pm
Matthieu DUVAL
(@matthieu-duval)
RE: Bad Vibrations
I have finished assembling my kit and I have the same issue.
Increase the speed to 110% helps to reduce the noise
Posted : 13/04/2025 5:52 pm
RE: Bad Vibrations
Loud noise at certain speeds (step frequencies) suggests that some printer part is rattling at specific resonance frequencies. Try touching the various enclosure panels while the noise occurs to see if you can dampen it. The cable cover in the back, above the power supply and electronics box, has been pointed out as a likely culprit; its two mounting screws do not really press it against the back wall.
Posted : 15/04/2025 5:45 am
Scott
(@scott-18)
RE: Bad Vibrations
Posted by: @jurgen-7
So yours doesn't suffer from loud resonance noises at specific speeds?
Posted : 15/04/2025 6:42 am
RE: Bad Vibrations
Posted by: @scott-18
No, I don't consider it noisy. Printing PLA in Structural mode, the chamber fans are the dominant source of noise. In Speed mode, the motors become audible, but I think it's really just the actual stepping sound, and no pronounced resonances at specific speeds. (Which might eventually improve further through calibrated phase stepping.)
Posted : 15/04/2025 6:59 am
RE: Bad Vibrations
To add to my post above: But nevertheless my printer shows VFAs, so they seem a separate issue from the acoustic noise. And when tuning the input shaper, I get lower resonance frequencies than expected, around 42 Hz in both axes (despite proper belt tension). So, still some unsolved mysteries...
Posted : 15/04/2025 7:19 am
RE: Bad Vibrations
Posted by: @juergen-4
Listening to an extended print, I realize that in Speed mode I also hear quite a bit of noise from the linear bearings on the Y axis. Similar in volume to the motor noise, but it does not have that characteristic speed-dependent pitch; it's more like white (or pink) noise. The right-side bearing might be a bit louder than the one on the left, but that's hard to tell apart.
The audible noise does not concern me, but I wonder whether the bearings are good or whether the noise is an indication that they are rougher than they should be. Do your Y bearings make similar noises?
Posted : 16/04/2025 9:04 am
Quin773
(@quin773)
RE: Bad Vibrations
I've been having that same issue. For me it is the x-axis mounts that vibrate during y-axis movements at certain speeds.
The sound goes away completely if  I put a finger on there. Not sure how this is fixable as of now.
Posted : 07/05/2025 5:19 am
Cédric
(@cedric)
RE: Bad Vibrations
Interesting to read about the different resonance noises, i found my kit built core one to be very quiet (though i mostly print structural speed), significantly better than my Mk3 which i could hear from the office above the workshop, with the core one i cant hear it at all, fans of course are noisey when printing PLA. I wonder if it has something to do with the assembly process, since some are noisy and some printers arent. I
Posted : 07/05/2025 2:27 pm
Page 5 / 8
