Aligning the Gantry - an easier way?
boB
 boB
(@bob-3)
My gantry was off by a small amount, about a 0.6 mm gap on the left side when the gantry was all the way forward on the Z axis.  I tried gently bending the gantry but the gap did not change much if any.  I am not happy with bending things so I looked for a better, gentler method.  Taking the "L" brackets off and aligning (bending) them seemed like the proper way but before that I tried an easier way: shimming.
I added a 0.5 mm shim between the gantry crossbar and the "L" bracket on the right side to even things out.  It did, the gap on the left side is maybe 0.1 mm if anything, close enough to zero for now and for the amount of effort invested.
Yes, a shim that is the full width of where the "L" bracket screws to the gantry would be better and I will do that soon, making a longer shim with the three screw holes to align with the parts.  Homing and calibrating the Core One didn't take long and if the print is skewed by 0.5 mm over the 220 mm travel I can probably live with that.
Veröffentlicht : 15/12/2025 2:58 pm
RE: Aligning the Gantry - an easier way?
As already stated in the response to your first copy of this post, shimming works, but is probably not the easiest way. It was one of the early approaches discussed here, back in April I believe.
I also disliked the idea of bending the L brackets in place, and bent them to exactly 90° before installing them when I built my kit. But having experienced how soft they are (you can easily bend them with your fingers), I no longer have any concerns with Prusa's suggested method of straightening the gantry in place, with the belts loose.
Veröffentlicht : 15/12/2025 3:05 pm
3 weiteren Personen gefällt das
boB
 boB
(@bob-3)
I tried straightening the gantry in place (belts loose) but did not have much success.  Maybe I was too gentle with it.  😉  If I ever have to do any maintenance/disassembly in the linear rail area I plan to remove the brackets and bend them to exactly 90 degrees but until then the shim may be good enough.
Veröffentlicht : 15/12/2025 7:33 pm
The shim is a totally valid solution; no need to replace it. It's just that finding suitable material, cutting it to size and installing will probably take longer than bending the gantry L brackets.
Having said that, I think the cleaner way to bend the brackets is to detach the gantry from the bracket on one side, then bend the other bracket. Then repeat on the opposite side. That avoids shear stress on the assembly while bending, and makes sure that each bracket is bent to 90° independently, without any remaining tension in the system.
Veröffentlicht : 15/12/2025 7:41 pm
Augendoc
(@augendoc)
I found I could reasonably adjust gantry skew following Prussia's method, but I completely detach the belt tensioners on each side. Push the gantry back half way, then pull one side toward you while pushing the other side away. It doesn't take much and you may have to go back and forth a few times, but eventually you will get the gantry square to the stops on each side. THEN reattach the belt tensioners, but only by a couple of threads on each side. if you have two 2.5mm hex drives, you can tighten right and left sides exactly the same and simultaneously Otherwise, one turn right side followed by one turn left side, then 1/2 turn, 1/4 turn, 1/8 turn, etc, making sure you alternate sides back and forth. When you tune the belts, adjust or tighten both sides the exact same amount and preferably at the same time if you have two hex drivers.
Veröffentlicht : 28/12/2025 5:15 am
lcvidal
(@lcvidal)
Mitglied
Mine failed Y axis test today, reason I've found was the belt tensioner had more "tooths" than required at the Nextruder holder, making the gantry misaligned.
Disassembled the Nextruder from the rail, left 4 tooths each side of the holder, adjusted the belt tension using the app without the Nextruder installed and reached 97Db.
After reassembling everything it passed the Y and X axis without asking me to adjust tensioners. Hope it helps!
Veröffentlicht : 05/01/2026 5:29 am
Mac-N4MCC
(@mac-n4mcc)
If you are using longer than normal belts, looking from the front, make sure the belts DO NOT come out UNDER the bracket.  If they are that long, pull them through the holes in the bracket on the right side.  The left side has grooves that they can come out of.  No clue why one side does and the other side didn't.  I had to order some XL belts to finally get my assembled.  My hand with arthritis could not deal with the 4 teeth.  Not sure the same number on both sides is valid.  I think that is idiosyncratic.
Make sure your belt tension pulleys are recessed in the holder and not touching the gantry.
One other thing, there are instructions for loosening the 6 gantry screws and letting the gantry "Settle" and then retightening in proper order.  That helped me a lot.
If Y axis fails continue, check  this thread
https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-owners-regretting-their-purchase/paged/5/#post-775761
Extra HAM (and eggs some say) Radio - N4MCC
Veröffentlicht : 11/01/2026 12:05 am
