Advanced Filtration unit counter - Firmware 6.4 RC
George
(@george-4)
Hi guys, i'm wondering if anyone else has an issue with the hours counter not working on their C1 with the Advanced Filtration Unit, on FW 6.4 RC.
I installed the filtration unit before the firmware was out, i had 80 hours already on it. So once the firmware was installed, i noticed that you could input in the counter the hours that was already in use. So i entered 80.
After a month or so of use, i noticed that the counter was still at 80. It hasn't counted up. Support said that it should have counted up. Anyone else has the same issue?
Veröffentlicht : 11/11/2025 10:06 am
RE: Advanced Filtration unit counter - Firmware 6.4 RC
Posted by: @george-4
I haven't notice but then I haven't checked either. I would suggest posting a bug report here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
Veröffentlicht : 11/11/2025 5:03 pm
George
(@george-4)
Will do.
Veröffentlicht : 11/11/2025 7:35 pm
mnentwig
(@mnentwig)
just to rule out the possibility: Is your filtering unit actually running? There is a GUI setting "filter all materials" that is off by default. Without turning it on, the filtration unit might - depending on what you print - never engage.
Veröffentlicht : 11/11/2025 7:45 pm
George
(@george-4)
Yeah its engaging, I feel the air coming out from the unit, sometimes i also set the air power manually. Also checked with the self test that the printer is indeed detecting it.
Veröffentlicht : 11/11/2025 7:48 pm
