[Rozwiązany] 6.3.5 alpha firmware
colemine
(@colemine)
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.3.5-alpha?fbclid=IwY2xjawLvRjhleHRuA2FlbQIxMQABHqulGs0Qm7d5QrW8zY0qje29AY30rm5z8jMXY6L5P02tGlBCPqXB0gmR4MUM_aem_8sJQaAwodkYRBadX5lPuNA
When I attempt to update this firmware, it says it is available with the start up of machine but then reports it is still using 6.3.4 RC.  Does this mean it did not load? or did they forget to change the part that changes the display?  I removed the the old file before I put the new one on the drive.
Anyone else?
Opublikowany : 24/07/2025 5:38 pm
HKOCH
(@hkoch)
RE: 6.3.5 alpha firmware
Just add the file manually like a printer file using Prusa Connect and update
Trust me, I'm an engineer 🙂 Always do your best. What you plant now, you will harvest later
Opublikowany : 24/07/2025 7:13 pm
colemine
(@colemine)
OOMG thank you.. I am pulling the stupid drive in and out, and back and forth when I didn't have too.  That worked like a charm.  Thanks so much.
Opublikowany : 24/07/2025 7:24 pm
1 ludzie polubili
Peter Bartl
(@peter-bartl)
Mine correctly states 6.3.5 alpha during boot up and at the top of the display once it is running
Opublikowany : 24/07/2025 7:25 pm
Frank
(@frank-2)
Going back to 6.3.4...  6.3.5 alpha made the searching for home a lot worse for me...
Opublikowany : 25/07/2025 9:38 am
Frank
(@frank-2)
Quick update, I went back, and yes....  way les issues with the "search for home" . It now does it in a couple of hits
Opublikowany : 25/07/2025 11:14 am
