0.25 nozzle keeps ketting clogged
Hi!
I've recently got myself a 0.25mm nozzle and I'm experiencing clogs almost every time I try to print something.
Settings are correct - standard C1 0.25 mm with prusament PLA, 0.15mm layer height. But after 10 minutes to 1 hour of printing it clogs and stops printing (clicking sounds from extruder, no filament going out of the nozzle). Heating to 270 degrees and using the needle helps to remove the clog.
Any ideas what might be wrong?
Opublikowany : 02/06/2026 3:58 pm
