XL and Core Belt. Are they the same??
mccluskey1
(@mccluskey1)
Does anyone know if the belts used on the XL are the same as used on the Core One, except for length?  I would like to use the XL belts on a Core One for easier installation then trim to length.
Extra HAM Radio - N4MCC
Posted : 13/12/2025 1:48 pm
RE: XL and Core Belt. Are they the same??
Posted by: @mccluskey1
They are the same (2GT belts, 6mm wide, 2mm teeth), but then my question would be why? Are you having a problem with your existing belts? If you are finding that the provided belts are "too short" then you are probably doing something wrong with the routing.
Posted : 13/12/2025 4:28 pm
mccluskey1
(@mccluskey1)
It is more about my hands. I have big and arthritic hands. I fumbled with the short exposed teeth a lot, and it is frustrating and time-consuming. I don't mind paying for longer OG belts then trimming them. I spent hours getting the originals installed, and by the time I had them working, my hands were sore. I resorted to purchasing a roll of GT2 that looks the same, but I am having a layer shift on large, wide prints and cannot get the Y-axis to pass, so I am going to replace the belt material I purchased with some OG Prusa belts for the XL just to see if that is my problem.
THX for help.
Posted : 13/12/2025 11:27 pm
Usually if the Y axis is not passing and you have layer shifts, that means either the belts are too loose, the gantry is bent or both. I would start by completely loosening the belts and check that the gantry is still square. Then follow this guide closely: Adjusting belt tension then most important point is that the gantry needs to start off square/parallel to the front of the frame and the belt tension screws need to be tightened by exactly the same amount and never independently.
Until the Y calibration passes, expect layer shifts.
Posted : 13/12/2025 11:44 pm
