I would really love to see an INDX (by Bondtech) for the Core One
Page 1 / 2
Vendolis
(@vendolis)
Watching the Demo video of the INDX on a Voron 0 as a 4 tool-head changer.. really makes me wish for some support for the Core One. Most likely could fit a 7 or 8 head changer. I think I would even be willing to give up 3-5 cm depth on the print volume for that feature. (And no.. I don't have the space to fit an XL, else I would have gotten one)
Maybe Prusa could fit 3 of their own head changers in the back of the Core One as a smaller option.. but the INDX looks really cool. Still has to be seen how well it work when its released.
Publié : 15/04/2025 12:10 am
1 personnes ont aimé
John Doe
(@john-doe-20)
RE: I would really love to see an INDX (by Bondtech) for the Core One
That is a pretty good idea.
I am in the same boat, as I would love an XL but just don't have the room for it. I have had multiple Prusa printers w/MMUs and it is a far better solution for multi-material printing than nothing at all but multiple tool heads is the "ultimate" solution.
Based on the INDX videos that I have seen I can see the overall print time for a multi-material job falling between the MMU3 times and the XL multi-head times due to the INDX extruder needing additional time to cool down the "in use" head to be switched out and then heating up the incoming head BUT due to the size (and price?) reduction of the INDX over the XL heads, can see getting more than the 5 heads currently supported by the XL into the available space of the CORE One.
Prusa ALREADY has the cross-bar support along the front face of the CORE One printer. Using the INDX w/the heads mounted along the front would simplify an "above the printer/top-hat" type of filament storage/dry box. Could even stack two, giving 10 material choices (if the front space would accommodate that many INDX nozzle units).
As I said at the start, I want an XL but don't have the space so expect to get a CORE One shortly after the CORE One MMU integrated solution is made available (hoping before May). I could easily see "migrating" from that solution to an INDX based solution if that becomes available either from Prusa or a third-party.
Publié : 15/04/2025 1:12 pm
Frank
(@frank-2)
Already filled in the bondtech survey to ask for core one support. Snazzy idea.
Publié : 15/04/2025 2:32 pm
I don't think this will be feasible as a retrofit. If you want your spare hotends stored in the back, the print head will need to sit behind the X rail, not in front as currently designed. So you would need to flip the X rail around, and would loose significant addressable print space in the front.
Maybe if Prusa teamed up with Bondtech on a "Core Two" with a modified layout of the CoreXY section. But I don't see them outsourcing such a central part of 3D printing technology as the extruder.
Publié : 15/04/2025 2:52 pm
John Doe
(@john-doe-20)
My "top of the head" thought was to have the hot-ends stored in the front of the CORE One BUT that would require a "Prusa version" of the INDX that loaded from the front.
What would be the problem with storing the hot-ends on the side? Rotating the entire x/y system by 90 degrees to the left or right. Should be a "snap" to update the firmware so that the printer still saw the x/y origin at the front, left. That way the heads could be stored above the side panel in the "dead space". Looks to be plenty of room there. Not sure if the existing movement frame supports the extruder going over far enough to do a hot-end swap but even if not now, it isn't rocket surgery to adjust that.
As to Prusa and the tech, with the Prusa numbers, they could work it out so everyone was happy [enough] and make it happen IF Prusa was unable to make something similar due to patents.
Publié : 15/04/2025 3:21 pm
Posted by: @john-doe-20
Umm... wouldn't the stored hot-ends get in the way of the gantry moving along the Y axis?
Publié : 15/04/2025 3:37 pm
Vendolis
(@vendolis)
The INDX seems to be having the tools in the front (Based on this video:
The question is if there is enough space for the print bed to clear the bed, if you mount the tools on the front bar. (I don't have my core One yet, so I don't know how much clearance there is).
Also, this would be in the way when viewing the print and taking it out. So, it might not be optimal. But you would not need to flip the xrail.
Publié : 15/04/2025 4:35 pm
Aszaunmi
(@aszaunmi)
Membre
I have a Voron 2.4 350 that is not used much anymore.  It was built for some large ABS prints for a customer.  I don't use it for much else since I have 4 other printers (MK4s's and 5 tool head XL.  I am hoping the INDX by bondtech works well as I will upgrade my Voron in a heart beat.  I have filled out their survey as well.  Fingers crossed it is as good or better than we expect.
Publié : 24/04/2025 11:10 pm
iftibashir
(@iftibashir)
If a Core One version was produced it would be a day 1 purchase from me.
Publié : 06/05/2025 1:14 pm
2 personnes ont aimé
vhubbard
(@vhubbard)
In the April 2025 video I saw they mentioned a November release target date.   Still in prototype.   They also mentioned a key element that was still missing was the bed probing element.    Reality may be sometime in 2026.
Wonder what projects Prusa is working on.
Publié : 06/05/2025 3:17 pm
Alexander
(@alexander-11)
Membre
Posted by: @iftibashir
Even without official support I might buy one and try and get it working. Most likely needs some modification to the core one such as rotating the gantry, some body work and possibly some additional software. But there is already support for the mmu and in essence the indx is not that different from the printers perspective. Whether it is waiting for a retraction or a tool changer should not matter too much for the integration on the software side.
Even the aforementioned preheating of the tool is not an issue as the tools are passive and cant be preheated on the indx anyways.
Publié : 06/07/2025 11:14 am
Posted by: @alexander-11
That sounds like a major project. Do you have experience with this kind of development, or similar hardware & firmware projects? Otherwise it might turn into a time and money sink.
Well, at the moment you can't buy one yet, right? And it is unclear to me whether Bondtech will even sell these as a generic component. Sounds like a potential support and customer satisfaction nightmare for them as well... They might well decide to offer these only for specific printers where they (or the printer manufacturer) have done the adaptation.
Publié : 06/07/2025 6:06 pm
Robin_13
(@robin_13)
Wow, what a cool idea.  I am thinking of a new FDM printer and was looking at different multifilament methods but this is fantastic and at a decent price.
I may restrict the next purchase to a printer that can use this or build my own printer.  Saw a very nice one that uses linear rails instead of rods.
Publié : 07/07/2025 3:50 am
Robin_13
(@robin_13)
Watched a couple of videos of the INDX print head and I am not sure if it will be able to modify the Core One to work with the INDX.  Cabinet is one of the issues.  Not sure if the linear rails on the Voron printers would be needed.  A moving gantry for the print nozzles may be an option for the MK4.
Publié : 07/07/2025 7:53 pm
iftibashir
(@iftibashir)
Can't see it working with the Core One.
Prusa should certainly touch base with them for the 'Core One V2' though.....
Publié : 07/07/2025 8:55 pm
Alexander
(@alexander-11)
Membre
Posted by: @jurgen-7
No. I have some experience in low-level software and integration, but no firmware projects. I do have some experience in hardware projects, but nothing dealing with this kind of stuff. I have the tools and time to get the knowledge, but you probably shouldn't bet your money on me actually getting to the end. I do however have time and money for fun projects, and this to me is just an excuse to delve deep into this kind of stuff.
For instance, looking at the MMU3 firmware on github it is quite readable and provides good insight into how the printer communicates with the MMU3 and how you could hook up something like an indx in there as well. Provided they have some "easy" way to control it. I have a microcontroller lying around I could probably smack in the middle to make it work.
In any case, looking at the videos I don't see anything that could be a real showstopper. Even the front loading without rotating the gantry seems doable, although it would block the view.
Publié : 07/07/2025 9:26 pm
Robin_13
(@robin_13)
From one of the videos on the INDX, the interview said that it is only a macro in the slicer software to work with the head change.  I think that is correct.  All it has to do is add some Gcode to tell the gantry to move and store the one head and grab the next head on a filament change and then do the wipe tower.  No firmware changes.
Is there enough room in the Core One cabinet for the extra heads, rail and tubes for the filament?   From the videos, I estimate that about 10-20cm will be required .  That would be the first issue to deal with.  If there is the room, it should be an easy addition.  Mounting the rail could be on the Core One case.  I will have to look at the videos again and see if I can get a better estimate of dimensions.
Publié : 11/07/2025 12:22 am
-Matt-
(@matt-26)
Membre
The INDX looks like a very neat system. I would love to see a kit for the core one.
However, could the core one's "all-steel exoskeleton frame" be a concern for the inductive heater? Wouldn't want the inductive heater to be inadvertently heating the enclosure when the print head is near the frame.
Publié : 18/07/2025 11:46 pm
Robin_13
(@robin_13)
Inductive heating is very localized.  Same with inductive stoves.  Metal needs to be in the field of the coil to heat up.
Publié : 25/07/2025 3:58 am
Vendolis
(@vendolis)
Making a very happy dance that this wish will be fulfilled.
Publié : 31/08/2025 5:12 pm
Page 1 / 2
