What filament dryer to use?
Page 2 / 3
iftibashir
(@iftibashir)
RE: What filament dryer to use?
Any suggestion for a filament drying thats cheap to run (ie low power consumption) to be used only for PETG.....
I don't need the higher temperatures needed for more advanced filaments.....I do want it to consume low power though.....
Posted : 15/09/2025 11:19 am
JM
 JM
(@jm)
As a number of people here have commented (myself included), the Sunlu S4 has a 4 reel capacity, a 'maintain humidity' setting (which switches off once the set humidity level is achieved and only switches back on once the humidity rises above another threshold - different to avoid hysteresis) thus saving power whilst the humidity is in an 'acceptable' band.
... and it's currently on offer on amazon (in the UK) ... for the next 10 hrs 🥴
The only downside is the chamber, although it accommodates 4 1Kg spools, doesn't differentiate between the spools (but as you're only printing PETG that shouldn't be a problem)
This post was modified 5 months ago by JM
Posted : 15/09/2025 12:03 pm
Chocki
(@chocki)
I have a creality space pi plus, the dual reel version. I find this works really well due to it being a blown hot air type. This in effect causes the hot dry air to swirl around the outside surface of the reel drying this very quickly, and this is the filament you will be printing with first, as more filament gets used more gets exposed to the hot air and you end up with nice no string prints, the dryer can take two reels so you can pre dry a reel whilst using one, but I have found the occasional wider reel which I sit across the two reel holders.
The only downside I have found is that it is a bit noisy so this can be intrusive, but it doesn't bother me as I sleep in a different room.
10 out of 10 for effectiveness and I gave my Sunlu dryer to my brother.
There is a small and I mean small compartment for silica gel sachets, but I find this is not needed at all.
Posted : 15/09/2025 4:08 pm
iftibashir
(@iftibashir)
Will take a look - thanks. Seems like its between Sunlu and Creality.
I don't really need it to feed to the printer from the dryer as once dry the filament will be removed and placed into a sealed AMS unit, in which I have dessicant and usually sits before 10% humidity - so I'm literally just after the drying function.
Posted : 18/09/2025 10:31 am
ultrametric
(@ultrametric)
Had a Creality Filament Dry Box 2.0, bought it for like 40 Euro and it broke within a few months, the digital display says random stuff.
The Sunlu S4 costs 140 Euro, dries 4 spools and has a nice build quality and touch screen.
Based on my experience, the recommendation is to not waste 40 Europe's on cheap crap. Go proper, or go without one.
Posted : 18/09/2025 10:35 am
WDLandry
(@wdlandry)
I’ve had the opposite situation with a single reel sunlu drier which didn’t last. Replaced it with the Creality space pi and haven’t had an issue after 100s of hours drying. Let’s be honest, all this stuff is cheaply made to meet a cost point.
4 filament drier isn’t the most economical either if you only need one dried. Really depends on your needs and use case, and available space.
I’ll echo one of the previous comments also around the benefits of a drier that allows drying while you print. It can be a time saver. Rather than having to give a spool a few hours of drying before a print. You can reduce that time and just leave it continue to dry while printing. Just avoids the “I want to print this… but shite my filaments been in the air for weeks”, and losing a few hours of print time
Posted : 18/09/2025 3:32 pm
Chocki
(@chocki)
If your drying you store then maybe consider a food dehydrator.
This post was modified 4 months ago by Chocki
Posted : 18/09/2025 4:07 pm
Crab
 Crab
(@crab)
Because I don't use an AMS, I am now a huge fan of Polymaker's Polydryer.. the one with multiple clear canisters that can sit on a dryer attached to its bottom. These are really my best solution and seem to work very well. In fact, I bought about 7 canisters and one of the dryer units and it is all I use now. I've tried 4 different drying solutions (except the food dehydrator) and this is the one that is the most convenient.
Posted : 18/09/2025 5:09 pm
Posted by: @crab
I love them for filament storage but the dryer option is definitely not for me. It doesn't get hot enough for PA (Nylon), PP and other technical filaments. Since the max temp is only 55C, Nylon has to stay in the dryer more than 24 hrs versus 8hrs for dryers that can reach 80C. I tried it out but it was cumbersome and the heater was too weak so I returned it. I use this which works well for me: Official Creality Filament Dryer 4 Spools
Posted : 18/09/2025 5:20 pm
Tim
 Tim
(@tim-21)
I use this: and it also makes good jerky.
https://www.amazon.com/dp/B07PY5M579
Posted : 18/09/2025 6:00 pm
JanLM
(@janlm)
I started with a Sunlu S1.  It worked good but for a print job but needed vacuum bags for storage. I have moved on to the Polymaker Drier. These work well and since each box comes with desiccant and container it will continue to dry the filament once the heating cycle is finished.  I have three boxes now so that I can print while filament is drying.  I have found during the humid summer months the Polybox hygrometer reads 28-33%, with indoor humidity with AC of 55-65%.
Posted : 18/09/2025 6:14 pm
Crab
 Crab
(@crab)
" I love them for filament storage but the dryer option is definitely not for me. It doesn't get hot enough for PA (Nylon), PP and other technical filaments. Since the max temp is only 55C, Nylon has to stay in the dryer more than 24 hrs versus 8hrs for dryers that can reach 80C"
The literature claims up to 73 degrees C.. and it has 3 "power" settings. The literature on the Polydryer also says it is suitable for nylon. Did you actually measure the temp inside?
Now I only use TPU, PLA and PETG as the engineering stuff I wouldn't use unless I had an actual lab area that was ventilated outside.  So for me the PolyDryer is a great option. I haven't used it often yet, but it seemed to dry PETG and PLA fine so far.. and I've only used a heat setting of 1 or 2 of the 3 settings possible.
Posted : 18/09/2025 6:20 pm
Posted by: @crab
I had an issue that my PA filament was still stringy, contacted them and they replied on power setting 3 I had to dry my filament for a minimum of 18hrs. I did measure it on setting 3 it only reached 55C. Maybe I had a bad unit but when they told me "minimum 18hrs for Nylon" this was too much. Also the hydrometer started at around 10% and after "drying" it was 24%? Almost as if it was pulling in moisture.
Like I said, the box itself is great. Using activated alumina, it stays around 10%.
I suppose for PLA, TPU etc it's probably fine but too restrictive for the types of filaments I use.
Posted : 18/09/2025 6:54 pm
Crab
 Crab
(@crab)
Posted by: @hyiger
I'm really disappointed about the engineering processes that are lacking in 3D printing companies.. Specifically in critical testing of their products. So the above posts makes me a bit sad as I've invested $200 in their product. So after 17 minutes, you can indeed see, in the probe position shown (and that is one accurate thermometer) that the chamber at that point shows only 50C after 17 min.. in 25 min it is up to 52C..
Now that is likely fine for my PLA/PETG/TPU as other parts of the chamber might be a bit hotter.. but far below what I'd expect for them to claim 73C on the hottest setting (and you can see that is the hottest setting).. So you are right.. not suitable for engineering filaments.. and I'm wondering if this is why I see this product on sale. I think the concept is great though.. I wonder if they can get the temps up.. I might do some more testing and do a video showing the results at all power settings.. as it seems that I might want to use the most powerful setting for both PLA and PETG. Damn.. Tired of being a beta tester with all this stuff..
Posted : 19/09/2025 3:09 pm
mark
 mark
(@mark)
Posted by: @crab
Posted by: @hyiger
That is one reason I went with the cheap food dehydrator. If it does not get to as high a temp and does not include a display that you can't trust to be accurate anyway, I just dry it longer. Except for the posting that said you can overdry TPU, which is has not been my experience, longer drying within reason has minimal downside.
Regards,
Mark
Posted : 19/09/2025 4:05 pm
WDLandry
(@wdlandry)
Kind of frustrating alright with the poly maker. I wonder if restricting the exhaust path to reduce airflow slightly would it allow the container to get to a higher temp.
Posted : 20/09/2025 8:30 am
Posted by: @wdlandry
I agree with @crab that it's a neat concept in that I could (in theory) print straight from the drier via the dry box then remove the dry box and store it without having to remove the spool. The drier itself however was so bad that it didn't take me long to decide to return it.
The dry boxes themselves I like. Yes they are more expensive than getting dry cereal containers and throwing in desiccant packs but then I like the 2 output ports for the filament, the semi-builtin hydrometer and the easy to open lid.
Posted : 20/09/2025 5:05 pm
GreenPea
(@greenpea)
This is my quick and dirty solution; food dryer from amazon (around 30 euro's) which can do up to 70 degrees and 24 hour runtime in steps of 5 degrees and 30 mins increments. Fitted with a cardboard sleeve so it fits two spools or three if I make the cardboard a bit bigger. Works like a charm, I throw in a moisture sensor and observe the process.
We have around 70% moisture here this time of years so I use it often, works like a charm. And as Tim already said: It makes good jerky 🙂
Loving the learning curve!
Posted : 21/09/2025 7:23 am
Artur5
(@artur5)
Guys, I recommend that you read the interesting document released by Czech manufacturer Fillamentum on this matter.
You'll see, for instance, that some filaments need to be dried above certain temperature or  you'll waste time and money.
https://filament2print.com/es/index.php?controller=attachment&id_attachment=2840
Posted : 21/09/2025 9:50 am
Crab
 Crab
(@crab)
I live in Nova Scotia, Canada, and our average humidity is 83%. (AVERAGE!, so that means in summer it is often above 90%). This would be similar to anyone on the Atlantic coast in Boston, New York, etc. So humid environments can be very common.. and a huge concern. I never realized that moisture can penetrate the vacuum seal of filament rolls (except those from Polymaker that I've gotten (PETG) in mylar). I've had to dry many spools of PLA after noticing stringing.
So I've tried 3 filament dryers.. Here, I tested the PolyDryer and PrintDryer Pro 3 that I have and results are below.. Here's my experience:
Sunlu S1: Great UI, temperature very accurate. Died in less than 5 months and neither Sunlu or the Canadian distributor "DigitMakers" would replace at their cost. So I was out $100 and I now never buy Sunlu products. I attempted to repair but it seemed to be a component failure)
PolyDryer results are below. And I have had great service and response from Polymaker for their filaments and other products. I really like their filament. Now they claim their unit heats to a max of 73C, but this is likely measured only an inch or two from the heat exit. In my probe placement you can see I get between 55-60 on their highest setting. I used PETG which the article in the previous post states use 65C for drying. I have noticed that on setting #2 for PETG (as recommended) It took a long time to get my PETG down to 15%. I think I will now use the max setting for my PETG. (and likely setting #2 for PLA although I've not tested). Since I only use PLA/PETG/TPU, the PolyDryer is fine for my needs. (But using setting #3 for PETG  (or setting #2 for PLA) is not recommended.. but I am willing to sacrifice a spool to see if I can cut down the drying time by hours.
The PrintDryer people have given me great customer service replacing my Pro V2 with a ProV3 base  (which gave me increased temp range) when I showed them a noisy fan. No cost. Great service. (disclosure, they are Canadian, but really has nothing to do with it). At setting 65C, the temps inside, with probe placement as shown in pics below, were 54-62. Likely pretty close since the heat exit was about 6-8 inches away where the temp is likely much closer to 65C. The nice thing about the Pro V3 is that it goes up to an 85C setting and although not tested, I'm pretty confident its air temps would far exceed the Polydryer for engineering filaments.
My Conclusions from these 3 print dryers.
1. Sunlu is not bad, but only a single unit and has zero warranty.
2. I love the Polydryer for my use because I have an open-frame MK3S+ and no MMU/AMS so printing directly from their boxes is an amazing convenience, as I can also dry at the same time. I likely would question if it is effective beyond PETG/TPU because of the very long heating times.. and am unsure if it would meet an optimal temperature. I use this often when I have a damp spool and don't want to wait to dry. I start the print with drying active.
3. The PrintDryer Pro3 works very well. I have made my own spool rod and I will heat 3 rolls of PLA/PETG at once (it fits, but the middle spool is over the heater so might be a bit of an issue). The Pro3 UI could be much better.. I understand they did it to keep costs down, but I'd like to see something a bit better.. But it has been the best of the 3 for me over drying about 100 spools.
4. Everyone should characterize their own dryer using thermometer probes at some point. I had to do this with my espresso machine and so had a bunch of temp probes available.. but it really shows you what your equipment will do. You can't read specs and really know what is going on.
5. Humidy is a real problem for me. Without constant maintenance of spools and desiccant, I can't get great prints.. and it takes a commitment. I recharge desiccant (50-112 gram bags) about every month by putting each in my microwave at a setting of 2 of 10 for 5 minutes.. and measure the result. Most bags take 2-3 cycles.
6. As an operational note, I often print multiple parts in sequential print mode because it limits the possibility of stringing. This mode has better inter-layer adhesion and generally I get very good surface finishes for PLA/PETG/TPU.
 564
Posted : 21/09/2025 2:45 pm
Page 2 / 3
