Undocumented G/M Codes
Was curious to know if there was any g/m-code that is undocumented. So I had the AI summarize if for me
From Prusa Knowledge Base: Buddy firmware-specific G-code commands
In the firmware (sorry the HTML tables are not getting formatted correctly)
Codes unique to Core One
| Code | Feature flag | Notes |
M870 |
HAS_CHAMBER_VENTS |
Automatic chamber vents — open (O) or close (C) the intake grille. The static_assert(HAS_CHAMBER_VENTS()) in the header means it will not compile for any other printer. |
M961 |
HAS_MANUAL_BELT_TUNING |
Manual belt tuning wizard. (Automatic belt tuning M960 is iX-only, not Core One.) |
M1980 |
HAS_DOOR_SENSOR_CALIBRATION |
Door sensor calibration wizard. MK4 has the door sensor hardware (HAS_DOOR_SENSOR) but only Core One has the calibration routine. Note: the source docstring incorrectly labels this M1979. |
Codes shared with iX and/or XL (not other printers)
| Code | Feature flag | Also on |
M1977 |
HAS_PHASE_STEPPING + calibration |
XL, iX — phase stepping calibration dialog |
M9200 |
Input shaper reload from config store | XL, iX (all printers with input shaper) |
M9202 |
HAS_PRECISE_HOMING_COREXY |
iX, XL, XL Dev Kit — clears CoreXY 9-point homing calibration, forcing a full recalibration on next G28 |
Codes that apply to all (or other) printers
| Code | Applies to | Notes |
G123 |
All | GUI manual move — moves axes at MANUAL_FEEDRATE, stops when a new G-code is queued |
P0 |
XL only | Park/drop current tool (toolchanger) |
M104.1 |
XL only | Early set hotend temperature — preheat a tool in advance using time-until-needed parameter |
M147 / M148 |
Printers with chamber filtration | Override chamber filtration on/off for current print only (ignores filament settings) |
M262–M268 |
MK3.5 / MK3.9 / MK4 | IO expander pin read/write/configure (XBUDDY board TCA6408A chip) |
M865 |
All | Manage filament parameters — set/query name, temperatures, abrasive flag, chamber settings |
M876 |
MINI only | Handle host prompt response / trigger warning popup by WarningType index |
M960 |
iX only | Automatic belt tuning — frequency sweep to measure resonance and tensioning force |
M1200 |
All (Prusa Connect) | Signal to Prusa Connect that the printer is ready for a new print job |
M1703 |
All with WiFi | Run Wi-Fi setup wizard (A = initial setup, I = load INI file, bare = normal wizard) |
M1959 |
All with ISC | Input Shaper Calibration wizard — sweep 30–80 Hz on X and Y axes, compute best shaper, optionally apply |
M1978 |
All | Fan selftest dialog — tests print fans, heatbreak fans, enclosure/chamber fans at 100% and 40% PWM |
M9140 / M9141 / M9150 |
All | Disable / query status / enable stealth mode (affects time estimation and motion limits) |
M9201 |
All | Reset motion parameters to defaults (Motion_Parameters::reset()) |
M9933 |
All | Internal Cork tracker — C marks a print-job milestone as done |
Respondido : 26/02/2026 12:23 am
3 les gusta
