Underextrusion and transport problems of the filament
Página 1 / 2
Bernd Laska
(@bernd-laska)
I have severe problems with printing a simple rectangular frame with a size of 190 x 190 x 50 mm. I tried the following steps, following the advices of the support https://help.prusa3d.com/article/under-extrusion-nextruder-printers_821253 :
1. Nozzle: replaced the nozzle and recalibrated the unit
2. Slicer settings: modified the slicer setting with regard to temperature (modifications in the range of 210 °C ... 230°C) and printing speed options
3. Gearbox: recalibrated the gearbox
4. Filament: Used new and different filaments Prusament Galaxy (black) and Gravitiy (grey)
Observations:
- Printing the first layer is good. The material sticks good to the plate
- After a while the filament extrusions is reduced or even the transport of the filament stops
- Noise can be heard from the extruder similar to a chattering, vibration.
Question:
Should I replace the idler leveler (A, B) or the extruder main plate. Is there any stepwise approach to find out the real root cause of the failure?
Respondido : 10/12/2025 9:15 am
RE: Underextrusion and transport problems of the filament
What kind of filament are you using? Is it PLA? Seems maybe your filament is clogging the nozzle.
Respondido : 10/12/2025 3:17 pm
Without a picture of the issue we can't do much more than guess - but the first thing I would check from your description is the extruder idler pressure.
To clear any possible partial clog I would first do a cold-pull.
To reduce the effect of infill back pressure change to either cubic or gyroid infill and re-slice.
Print - it might now be fixed (unlikely) but if not tweak the extruder idler pressure, it could be out either way so keep careful count of the turns; I would begin with half a turn at a time, test printing in between.   If that doesn't help undo all the turns, print again and show us a picture of the problem
Respondido : 10/12/2025 3:57 pm
Bernd Laska
(@bernd-laska)
I tested the setup with two different PLA Filaments The first one was Prusament Galaxy (black) and the second Gravitiy (grey). I had similar problems with PETG and a hotend temeparture of 245°. Clogging shouldn't be the problem. As written before I changed the nozzle and in addition the first layer priniting and some following layers is ok. In my opinion after appr. 30 - 60 min the underextrusion starts.
Respondido : 10/12/2025 8:54 pm
Bernd Laska
(@bernd-laska)
Posted by: @diem
Thank you for your advice. I will start the printing again and will take some pictures and publish them here in the forum.
Regarding your first proposal: I will clean the transport unit "idler leveler (A, B) or the extruder main plate" and adjacent parts of the extruder with pressurized air. One question: What do you mean with cold pull? Should I remove the nozzle and pull a cold filament through the transortation unit?
Change of infill: I already use gyroid infill but I will start printing again showing some pictures here.
Changing the idler perssure will be the next step after having finished the first proposal.
As I already mentioned before I will take some pictures to better explain the priniting results in dependence of the parameters and changes.
Respondido : 10/12/2025 9:12 pm
Bernd Laska
(@bernd-laska)
@diem
How can I enclose some pictures. The add media button show any reaction.
Respondido : 10/12/2025 11:41 pm
Bernd Laska
(@bernd-laska)
Respondido : 10/12/2025 11:50 pm
https://help.prusa3d.com/article/cold-pull-31702-core-one-35702-core-one-l_930551
Respondido : 11/12/2025 11:37 am
Bernd Laska
(@bernd-laska)
Thank you for advice. It's just the prposal made by the 24/7 Hotline. I will continue the discussion with the hotline and after having concluded the issue, I will summarize the findings here, hopefully soon.
The Hotline proposed so far to:
- change in the slicer the nozzle type
- to update the Firmare version
- to carry out the cold pull test
Thanks in advance for your helpfull comments
Bernd
Respondido : 11/12/2025 12:13 pm
I am not happy with the state of your build sheet but the filament is sticking so apart from a reminder to keep it clean I will assume it is not the cause.
The extruder gears are reasonably clean, while they are open I would blow out any dust - that chattering vibration may have been the gears grinding into stuck filament in which case there may be dust behind the gears.
The pictures are not clear but I don't see any damage around the opening where the filament runs into the top of the nextruder tube, correct me if I am wrong.
The galaxy filaments contain particles of glitter so are a little more likely than plain filament to display problems but again, I doubt the filament is the cause.
So: let's take a look at the file.  Please save your project as a .3mf file
Files > Save Project as
Respondido : 11/12/2025 10:53 pm
Bernd Laska
(@bernd-laska)
First of, Thank You for your comprehensive comments and advices
Comment: I agree, at the beginning I cleaned the sheet with a not suited sponge. Therefore there are some scratches to be seen. But the first layer sticks good to the surface of the sheet
Comment: I cleaned this gear area and the filament transportation unit with pressurized air. So it should be clean now
Comment: In my opinion the guidance of the filamnet is ok. There are two tubes / sections for guiding the filament along the transport wheel which looks nice. I'm not so sure about the mobility of the bearings, which press the filament onto the gear wheel/ transportation wheel.
Comment: I used two types of filament. Galaxy and Gravity. Both show the similar results.
Comment: Thank you for your support. Good proposal. I'll try to submit the .3mf File
Short information from the three chat sessions with the 24/7 chat:
- Change the nozzle type from HF to standard in the slicer: see included 3mf file
- Carry out a cold pull – Done
- Update the Firmware version – Done
- Check the idler spacers - Done (only short visual inspection with pictures)
- Cleaning of the filament transportation section - Done with pressurized air
Printing results after measures: No significant improvement, looks a little bit "nicer"
Open task: Replace the Hotend unit, spare part is on the way. I proposed to check the resistance of the thermistor and the heating resistor. But if the issure is time or temperature dependent, a static measurement won't give the right information.
Looking forward to your comments on the 3mf File
Respondido : 12/12/2025 8:34 am
Bernd Laska
(@bernd-laska)
@Diem
the file, which I attached disappeared - second trial
Respondido : 12/12/2025 8:39 am
Zip the 3mf before posting.
Respondido : 12/12/2025 9:10 pm
Bernd Laska
(@bernd-laska)
I transformed the file into a Zip-File and added it via the "Select File" button. The submission of the original 3mF- File as well as the Zip- File seems to fail. Hopefully the next trial will be successful.
These are the two files which I tried to enclose into the post via the "File Select" button. Do you have any advice, which option I can try to succeed.
The 3D Modell appr (190 x 190 x 50 mm), which I tried to print ist shown in the following picture:
Respondido : 12/12/2025 10:01 pm
Bernd Laska
(@bernd-laska)
One additional information. I had access to a Prusa Mini 3D Printer and could sucessfully print the frame. So the design itself should not be the root cause for the malfunction and observed failures. Because of the size of the frame I had to subdevide the part into four smaller sections so that it could be printed on the 180 x 180 mm plate of the Mini.
Bernd
Respondido : 14/12/2025 1:08 pm
File still not coming through:  Zip the file, store it somewhere convenient and browse to it with the button below your post.
Respondido : 14/12/2025 7:07 pm
Bernd Laska
(@bernd-laska)
I think I followed your approach. As you can see, the project/ file is transformed into a zip-Folder. I used the corresponding button below my post. After having selected the file, one can see the filname below the post window. Pressing "Add reply" - I thought the submission of the zip file will be launched - one can read the post but the file disappeared. The same is true if you sellect the "Preview".
Perhaps this is an issue with any firewall settings. I will change my browser, as it is necessary for the 24/7 Live-Chat with Prusa. Google chrome doesn't work for the Live-Chat tool.
Respondido : 14/12/2025 9:16 pm
Bernd Laska
(@bernd-laska)
Further trial of file transmission! Now with Microsoft Edge Browser
Respondido : 14/12/2025 9:22 pm
Ok, the base file seems reasonable, it should print OK.  You are using organic supports, snug would be better here.
You seem to have edited the startup code, revert to a default startup code to eliminate one possible source of errors.
If the above doesn't help try raising the print temperature by 5°C.
Respondido : 15/12/2025 3:56 pm
Mac-N4MCC
(@mac-n4mcc)
Just an FYI (been there) if you have had the gears out of the nextruder, male sure the tiny thin washer went back behind them.
Extra HAM (and eggs some say) Radio - N4MCC
Respondido : 16/12/2025 12:06 am
Página 1 / 2
