Underextrusion and transport problems of the filament
Bernd Laska
(@bernd-laska)
Mitglied
I have severe problems with printing a simple rectangular frame with a size of 190 x 190 x 50 mm. I tried the following steps, following the advices of the support https://help.prusa3d.com/article/under-extrusion-nextruder-printers_821253 :
1. Nozzle: replaced the nozzle and recalibrated the unit
2. Slicer settings: modified the slicer setting with regard to temperature (modifications in the range of 210 °C ... 230°C) and printing speed options
3. Gearbox: recalibrated the gearbox
4. Filament: Used new and different filaments Prusament Galaxy (black) and Gravitiy (grey)
Observations:
- Printing the first layer is good. The material sticks good to the plate
- After a while the filament extrusions is reduced or even the transport of the filament stops
- Noise can be heard from the extruder similar to a chattering, vibration.
Question:
Should I replace the idler leveler (A, B) or the extruder main plate. Is there any stepwise approach to find out the real root cause of the failure?
Veröffentlicht : 10/12/2025 9:15 am
RE: Underextrusion and transport problems of the filament
What kind of filament are you using? Is it PLA? Seems maybe your filament is clogging the nozzle.
Veröffentlicht : 10/12/2025 3:17 pm
Without a picture of the issue we can't do much more than guess - but the first thing I would check from your description is the extruder idler pressure.
To clear any possible partial clog I would first do a cold-pull.
To reduce the effect of infill back pressure change to either cubic or gyroid infill and re-slice.
Print - it might now be fixed (unlikely) but if not tweak the extruder idler pressure, it could be out either way so keep careful count of the turns; I would begin with half a turn at a time, test printing in between.   If that doesn't help undo all the turns, print again and show us a picture of the problem
Veröffentlicht : 10/12/2025 3:57 pm
Bernd Laska
(@bernd-laska)
Mitglied
I tested the setup with two different PLA Filaments The first one was Prusament Galaxy (black) and the second Gravitiy (grey). I had similar problems with PETG and a hotend temeparture of 245°. Clogging shouldn't be the problem. As written before I changed the nozzle and in addition the first layer priniting and some following layers is ok. In my opinion after appr. 30 - 60 min the underextrusion starts.
Veröffentlicht : 10/12/2025 8:54 pm
Bernd Laska
(@bernd-laska)
Mitglied
Posted by: @diem
Thank you for your advice. I will start the printing again and will take some pictures and publish them here in the forum.
Regarding your first proposal: I will clean the transport unit "idler leveler (A, B) or the extruder main plate" and adjacent parts of the extruder with pressurized air. One question: What do you mean with cold pull? Should I remove the nozzle and pull a cold filament through the transortation unit?
Change of infill: I already use gyroid infill but I will start printing again showing some pictures here.
Changing the idler perssure will be the next step after having finished the first proposal.
As I already mentioned before I will take some pictures to better explain the priniting results in dependence of the parameters and changes.
Veröffentlicht : 10/12/2025 9:12 pm
Bernd Laska
(@bernd-laska)
Mitglied
@diem
How can I enclose some pictures. The add media button show any reaction.
Veröffentlicht : 10/12/2025 11:41 pm
Bernd Laska
(@bernd-laska)
Mitglied
Veröffentlicht : 10/12/2025 11:50 pm
https://help.prusa3d.com/article/cold-pull-31702-core-one-35702-core-one-l_930551
Veröffentlicht : 11/12/2025 11:37 am
Bernd Laska
(@bernd-laska)
Mitglied
Thank you for advice. It's just the prposal made by the 24/7 Hotline. I will continue the discussion with the hotline and after having concluded the issue, I will summarize the findings here, hopefully soon.
The Hotline proposed so far to:
- change in the slicer the nozzle type
- to update the Firmare version
- to carry out the cold pull test
Thanks in advance for your helpfull comments
Bernd
Veröffentlicht : 11/12/2025 12:13 pm
I am not happy with the state of your build sheet but the filament is sticking so apart from a reminder to keep it clean I will assume it is not the cause.
The extruder gears are reasonably clean, while they are open I would blow out any dust - that chattering vibration may have been the gears grinding into stuck filament in which case there may be dust behind the gears.
The pictures are not clear but I don't see any damage around the opening where the filament runs into the top of the nextruder tube, correct me if I am wrong.
The galaxy filaments contain particles of glitter so are a little more likely than plain filament to display problems but again, I doubt the filament is the cause.
So: let's take a look at the file.  Please save your project as a .3mf file
Files > Save Project as
Veröffentlicht : 11/12/2025 10:53 pm
Bernd Laska
(@bernd-laska)
Mitglied
First of, Thank You for your comprehensive comments and advices
Comment: I agree, at the beginning I cleaned the sheet with a not suited sponge. Therefore there are some scratches to be seen. But the first layer sticks good to the surface of the sheet
Comment: I cleaned this gear area and the filament transportation unit with pressurized air. So it should be clean now
Comment: In my opinion the guidance of the filamnet is ok. There are two tubes / sections for guiding the filament along the transport wheel which looks nice. I'm not so sure about the mobility of the bearings, which press the filament onto the gear wheel/ transportation wheel.
Comment: I used two types of filament. Galaxy and Gravity. Both show the similar results.
Comment: Thank you for your support. Good proposal. I'll try to submit the .3mf File
Short information from the three chat sessions with the 24/7 chat:
- Change the nozzle type from HF to standard in the slicer: see included 3mf file
- Carry out a cold pull – Done
- Update the Firmware version – Done
- Check the idler spacers - Done (only short visual inspection with pictures)
- Cleaning of the filament transportation section - Done with pressurized air
Printing results after measures: No significant improvement, looks a little bit "nicer"
Open task: Replace the Hotend unit, spare part is on the way. I proposed to check the resistance of the thermistor and the heating resistor. But if the issure is time or temperature dependent, a static measurement won't give the right information.
Looking forward to your comments on the 3mf File
Veröffentlicht : 12/12/2025 8:34 am
Bernd Laska
(@bernd-laska)
Mitglied
@Diem
the file, which I attached disappeared - second trial
Veröffentlicht : 12/12/2025 8:39 am
Zip the 3mf before posting.
Veröffentlicht : 12/12/2025 9:10 pm
Bernd Laska
(@bernd-laska)
Mitglied
I transformed the file into a Zip-File and added it via the "Select File" button. The submission of the original 3mF- File as well as the Zip- File seems to fail. Hopefully the next trial will be successful.
These are the two files which I tried to enclose into the post via the "File Select" button. Do you have any advice, which option I can try to succeed.
The 3D Modell appr (190 x 190 x 50 mm), which I tried to print ist shown in the following picture:
Veröffentlicht : 12/12/2025 10:01 pm
