Thumb screws vibrating loose on Core One
Membre
Anyone else having an issue with the thumbscrews vibrating loose after several prints and the nozzle dropping and scratching the bed?
Publié : 04/05/2026 10:09 pm
I didn't have both thumbscrews get loose but I did have one do that. It happened when I was still very new to the printer, tried to remove the nozzle without loosening the screws, and bent the tip of one of the screws. I had to order replacements. Unless you frequently remove nozzles maybe a small amount of blue Loctite?
Publié : 04/05/2026 10:12 pm
1 personnes ont aimé
Membre
RE: Thumb screws vibrating loose on Core One
Thanks.  I might try that.
Posted by: @hyiger
Publié : 04/05/2026 10:46 pm
Geoff Steele
(@geoff-steele)
I do swap nozzles somewhat frequently and a while back noticed the hot-end had rotated a little and found it had loosened off and could easy be moved by hand. I've not had the nozzle fall out and/or scratch the bed so must have just caught it in the nick of time. Checking these thumbscrews has become part of my between-print checklist.
TBH I'd never thought to ask if this was normal, a potential problem, or just another me-issue before seeing this thread
Publié : 04/05/2026 10:59 pm
Robin_13
(@robin_13)
I wonder if you put a small "O" ring under the head, it may work like a lock washer due to the friction.  I have seen similar things done with other equipment.
Publié : 05/05/2026 2:51 am
Geoff Steele
(@geoff-steele)
I can imagine the lower one might cop a bit of heat. If the nextruder was long-term I might consider it, though checking those two thumbscrews when I clean the nozzle between prints isn't a hassle really
Publié : 05/05/2026 3:51 am
Membre
I have added this to my checklist also.
Posted by: @geoff-steele
Publié : 05/05/2026 10:40 am
Membre
Interesting idea - thanks for the suggestion.
Posted by: @robin_13
Publié : 05/05/2026 10:41 am
