Resume after pause problem
NarlyB
(@narlyb-2)
I paused the printer for really loud harmonic noise to check Y axis lube.
On resume the print head was a bit to low and the filament was not able to feed. The nozzle started to scrape the previous layer.
The extruder was making that skip sound and the filament was not extruding.
The printer did not throw an error.
The print was a fail
Verified filament extrudes by forcing a filament change.
Has anyone experience this.  This was my second print on this printer.
Respondido : 22/02/2025 4:30 pm
1 les gusta
j3llyh34d
(@j3llyh34d)
I've also seen issues with resume.  In my case it attempted to resume ~4mm above where it should.
That bug is my only failed print in 100+ hours printing over the last week.
Mini+, MK4+MMU3, MK4S, Core One, XL.
Respondido : 23/02/2025 3:39 pm
LordMelkor
(@lordmelkor)
I'm having the opposite issue... on resume the nozzle isn't going low enough, so the filament doesn't adhere properly. Was able to replicate--same object paused at different heights. when I went to resume it missed by ~1 layer, causing failure.
Respondido : 23/02/2025 6:13 pm
LordMelkor
(@lordmelkor)
RE: Resume after pause problem
Respondido : 23/02/2025 6:19 pm
AlanB
(@alanb)
Miembro
I just experienced a resume after pause problem on my CORE One. Current 6.3.0 firmware. Momentary pause to pull a bit of junk off the printhead sock, on resume the motions were loud and jerky, and the print was failing. It appeared the acceleration had gone much too high, motions were no longer smooth and quiet. Lost 2 hours of print time and material. 2.9.0 PrusaSlicer. Will avoid pause until this is addressed. I've had pause work, so apparently there is some race condition where parameters get lost.
Respondido : 20/03/2025 7:16 pm
WarezMonkey
(@warezmonkey)
I am pretty sure this is the same issue: it has been reported in other posts and in github. Prusa is already bundling a fix into the next firmware: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4505#issue-2889065150
Respondido : 21/03/2025 5:47 pm
