Prusa Core One Branded Build Plates Are Awful
Página 2 / 2
pjs37
(@pjs37)
RE: Prusa Core One Branded Build Plates Are Awful
I must admit my experience with the build plates from Prusa while not awful has not been something I felt ever reached the levels of praise others have heaped onto them ( i been through 6 plates now across two printers).  I have always had issues with warping, prints simply just not sticking, or weird wrinkle issues.  The textured plates were the worse for me, the smooth sheet worked ok, the satin I been using more but I have mixed opinions on that so far.  I find I always need to run my heat bed 5-10 degrees hotter then any of the recommended settings just to prevent warping as bad and even then, it will still almost always warp.  Someday I will get around to looking at some 3rd party plates just to see how they fare.
Curious to see what others have as a recommendation to try.
Respondido : 11/09/2025 3:37 am
domble
(@domble)
I've only printed PLA so far on the Core One. With the satin plate, straight out of the packet without any sort of cleaning. No problems at all.
Respondido : 11/09/2025 8:21 am
Jameslmr
(@jameslmr)
I had quite a few issues with PETG warping on a Core One branded textured plate. I read somewhere that lightly scratching the surface of it with a scotch-brite sponge can help. This worked really well for me and prints stick perfectly for me now. I make sure to wash the sheet with a smooth sponge, and with soap and water every ten prints or so.
Annoying that you have to essentially post-modify the sheet for it to work well.
Respondido : 11/09/2025 9:29 am
GBMaryland
(@gbmaryland)
I clean then with soap and water.  Then wipe them with 100 isopropanol between builds. I have not had a problem with any of them over 100s of hours of printing. The glacier build plates are very good and reasonably priced.
Respondido : 11/09/2025 11:04 am
I've had no trouble with random plates I've picked off of Amazon for $15-25. You know, the companies with names that are mostly consonants like SVBONY or GRTBTU. Anyway, I don't have to jump through hoops to get a good first layer.
Respondido : 11/09/2025 5:10 pm
Página 2 / 2
