Possible bug or error in Gcode ? (Layer shift)
Hi all.
Today I tried to print a model and had a major fail with my print with masive layer skip. I assumed that my bridge infill (blue lines) caught nozzle and caused the issue. So I started new print and watched around same time of previous failure.
When part from picture came, printer finished bridge infil (checked for blobs and other stuff > nothing there), printer made unexpected noise and start to print next layer with exact same shift as before. G code show some movement to nowhere and then next layer.
I have checket my belt tensions, pulleys etc. and everything is OK. Other files print OK. Is it some kind of error or bug ? Or I am missing something here ?
Core ONE+, Firmware 6.4.0
Thank you !
RE: Possible bug or error in Gcode ? (Layer shift)
I had a print of multiple parts, small parts, that printed fine several times, then I got a layer shift. Reprinted. Got the layer shift at the same point. I did a Repair STL file in Prusa Slicer and resliced the file and the problem stopped.
Extra HAM (and eggs some say) Radio - N4MCC
