original Prusa Accelerometer on Core One
mark584
(@mark584)
Membre
I am installing the accelerometer I purchased from Prusa on my Core One.  The cable from the back of the printer to the print bed is not long enough.  Do you know of a source for a longer cable and the specifications when ordering.  I would prefer a premade cable.
Publié : 10/05/2025 5:04 pm
Kachidoki
(@kachidoki)
RE: original Prusa Accelerometer on Core One
I don't I have length issue with mine. Do you route the cable through the rear panel?
Publié : 10/05/2025 5:44 pm
1 personnes ont aimé
pjs37
(@pjs37)
There should be two cables...One is the small jumper cable for use inside the electronics box from the Wifi to the board and a longer one from the wifi module to the accelerometer if you just bought it recently let Prusa know maybe you are missing the one longer cable you should have.
Publié : 10/05/2025 6:04 pm
iftibashir
(@iftibashir)
The cable is more than long enough. As highlight above, the small jump cable goes from the board to the wifi module (see my video link in sig).
The accelerometer itself then goes through the rear panel (which you have correct) and connects to the port on the wifi module. I recall there being slack in the cable even after connecting......
Publié : 10/05/2025 7:28 pm
