Layer lines problem
Jwo
 Jwo
(@jwo)
Layer lines problem
Hello everyone,
I've been getting some visible layer lines at a certain height when printing but somehow only in a specific type of prints (large box-like models)
The problem.
A fine print.
What could it be and how do I troubleshoot this problem?
Thank you all in advance.
Publié : 23/01/2026 2:27 pm
jan.d.slay
(@jan-d-slay)
RE: Layer lines problem
I'm guessing that the floor ends right at that line behind it and only the wall continues upwards?
Publié : 23/01/2026 2:42 pm
This is the classic benchy hull line problem. In short it won’t be simple to eliminate. You have a floor with infill, several top layers and a wall. You can research online (there is a recent YouTube video) that describes and provides some solutions to the problem. The short answer is it’s not trivial to get rid of them. An easy way if you don’t mind the appearance is to use a fuzzy skin.
Getting rid of layer lines in general can be done by switching to matte or carbon fiber filaments.
Publié : 23/01/2026 3:44 pm
1 personnes ont aimé
Or search this forum for "buldge" (sic). Dozens of pages, no generally applicable solution.
Publié : 23/01/2026 4:06 pm
PaKo
 PaKo
(@pako)
Hi, try "External perimeters first" option in "Advanced section" of "Layers and perimeters" settings. (slicer must be switched into "Expert" mode)
Publié : 23/01/2026 7:21 pm
brianjordan
(@brianjordan-2)
Posted by: @jwo
Hello everyone,
The problem.
A fine print.
This, from Slant 3D, is a comprehensive explanation of this issue.
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Publié : 23/01/2026 7:36 pm
Jwo
 Jwo
(@jwo)
I’m not sure if I should feel good about this or not since it’s such a tough flaw to fix.
Yeah the floor inside this geometry is what creates this issue.
Unfortunately, having a texture or fuzzy skin is not viable for this model, will have to find another work around.
I tried making the outer walls first, but it ended up with a bunch of unconnected layer lines. Then I gave that hull lines solution from the video a shot, but that didn’t work either.
But thank you all for your insight on the problem! 😀
Publié : 28/01/2026 10:43 am
Posted by: @jwo
The video discusses multiple solution approaches. Which one(s) did you try?
Based on that video and other experiences I have seen described, decoupling the walls from the large continuous inner floor surface is the "proper" solution. A groove between floor and wall, or an embossed or debossed grid pattern on the floor, seem equally effective.
Publié : 28/01/2026 12:48 pm
Jwo
 Jwo
(@jwo)
Yes, i tried that solution. Maybe is not perceptible in the photo. But here is the geometry:
Publié : 28/01/2026 2:36 pm
