How to decrease Print Start Time
GeneMpls
(@genempls)
I see an older thread on this- hoping there might be some other fixes for those of us who only print PETG and short prints for prototypes. I have a MK4s also.
Posted : 09/12/2025 7:11 pm
For the absorb heat phase you can either press "skip" on the UI screen or disable for certain filament types in gcode. To do the later you can add the following to the Printers->Custom G-code section or you can simply remove (or comment out) the G29 G ; absorb heat line.
{if filament_type[initial_tool] !~ /.*(FLEX|PLA|PETG).*/}
G29 G ; absorb heat
{endif}
As for (temporarily) skipping the bed leveling and reusing the previous mesh. You can comment out this section:
; MBL
M84 E ; turn off E motor
;G29 P1 ; invalidate mbl & probe print area
;G29 P1 X150 Y0 W100 H20 C ; probe near purge place
;G29 P3.2 ; interpolate mbl probes
;G29 P3.13 ; extrapolate mbl outside probe area
;G29 A ; activate mbl
Also, for example, perhaps save the profile as "Prusa CORE One 0.4 nozzle (skip bed level)" I wouldn't skip bed leveling all the time. If you are doing a print, remove the previous print then do another then it's probably safe to skip. I usually don't bother with this unless it's a really small print.
Posted : 09/12/2025 7:57 pm
mnentwig
(@mnentwig)
What I'd do is go through the profile's G-code and remove the problematic codes. M109 and G29 G come to mind (for me it's OK to calibrate at uncontrolled nozzle temperature but of course you need it once for printing)
edit 1 min late - see above.
Posted : 09/12/2025 7:58 pm
GeneMpls
(@genempls)
RE: How to decrease Print Start Time
I would love to see something in the PrusaSlicer to bypass it {hint,hint Jos}- I built mine and don't even have all the cladding on the case. Thanks guys, Gene
I am guessing that they never considered anyone using without needing the heatsoak, but I have Prusas going back many years and we do exist.
Posted : 10/12/2025 4:46 pm
Mac-N4MCC
(@mac-n4mcc)
I read that people do not like the several-minute start-up to print, but when printing things from Printables, and the code does not do that, I have much lower success with the prints. Considering most prints are an hour or much more, the few minutes are not important to me.
Extra HAM Radio - N4MCC
Posted : 13/12/2025 11:57 pm
Posted by: @mccluskey1
When printing things from Printables, pre-sliced g-code is I suppose convenient but it's always better (in my opinion) to slice it yourself. Also, if I have a print that only needs 10-15 minutes I certainly don't want to wait 20 minutes for it to start. Depending on the geometry of the part I tend to skip the heat soak. For filament that are tricky to print, i.e. have a tendency to warp, I always use a heat soak.
Posted : 14/12/2025 12:06 am
Protoncek
(@protoncek-2)
Well, that would depend on material. If you for example print with ASA  or ABS then preheat is very welcome, since even with preheating part too easily creates an elephant toe. And it doesn't matter if print is hours long or just 15 minutes - if it curves it's useless.
I have two profiles created: one with preheat disabled (G29 G line commented out) and original one, then i choose what i need at that time, but since i mostly do PLA and PETG i mostly use "no preheat".
From i've read this "preheat" was made with intention to increase precision - it's for metal parts to warm up and extend to a working point, so that during printing later they stay put and doesn't extend (metal extends with heating). If that is made during print then part would (theoretically, that is) become somewhat distorted.
Posted : 15/12/2025 6:45 am
Posted by: @protoncek-2
That's why I've done it this way:
G29 G ; absorb heat
{endif}
For ASA, PC etc I'll sort of eyeball it and press the "Skip" on the UI if I feel the part doesn't need a heat soak.
Posted : 15/12/2025 5:21 pm
Bruce Labitt
(@bruce-labitt)
Posted by: @hyiger
G29 G ; absorb heat
{endif}
I find this delay for the non-technical filaments to be ridiculous.  Yes, it is good for some things, but waiting an extra 15-20 minutes for a 20 minute print doubles the print time.  That is NOT an improvement.  About your edit.  I'm not skilled in this stuff (yet).  So I search for the line G29 G ; absorb heat in the section Printers > Custom G-code and comment it out, and then add your code.  So it would look like this?
;G29 G ; absorb heat
G29 G ; absorb heat
{endif}
And this would kill absorb heat for these three filaments?  Other filaments would do the absorb heat?
Posted : 03/01/2026 10:30 pm
"Absorb heat" is a very important function in an enclosed chamber with a rigid metal frame. It allows the frame, heat bed and chamber temperatures to stabilize. This has several benefits, among them: a better bed mesh estimation which affects the first layer (and adhesion), preventing parts from separating prematurely from the build plate due to late thermal expansion and more even chamber temperatures at the beginning of the print.
For filaments that don't require a heated chamber and can print on a warm to cold bed, heat soak is entirely not necessary in my opinion. For engineering filaments that I use for functional parts, if they are large I most definitely wait out the heat soak. For smaller parts I aways skip.
The code above will always skip for those 3 filament types only. You can instead just comment out G29 G, slice your object and print which will skip the heat soak. You can then just not save the preset. Or you can just press skip on the printer's UI.
Posted : 03/01/2026 10:49 pm
