firmware 6.5.3 causes connection problems and corrupted files
This is becoming a habit; yet another firmware update causing serious problems by corrupting files sent via Prusa Connect from Prusa Slicer. The regression continues, and the machine suffers from frequent stops mid-print, the print head jammed on the bed with a horrible, frantic noise from the stepper motor. I've had enough!
RE: firmware 6.5.3 causes connection problems and corrupted files
I've had one case where a large g-code file sent via PrusaConnect caused the print to stop with a g-code corruption error. I've haven't seen it since though. I swapped out the USB drive thinking maybe it was there. Not sure it is related or just a coincidence.
My advice is to raise a bug issue here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
