Existing MMU Nextruder & MMU3
Mk4User
(@mk4user)
I had the MK4S with MMU3, everything in the final state, i.e. the Nextruder had the MMU3 changes done to it. That MK4S is now upgraded to a Core One, which has been working great for a while - no issues whatsoever.
I read the MMU3 Core One assembly manual. For my own reasons I want to do the physical setup completely differently, that is I will have the MMU3 somewhere else, will do my own buffer and spool solution.
Am I correct in assuming that this should work and be the minimal steps to connect the MMU3:
- Do the physical setup whichever way I see fit.
- Connect the cable to the buddy board as per instructions.
- Connect a 450mm PTFE between MMU3 and Nextruder (the length of the "lite" version from the manual).
- Enable MMU3 in the menu.
- Do the setup as in the manual (set the length to 450mm).
- No changes whatsoever to the Nextruder or the MMU3 as those have been done during the MK4S days already.
Have I missed anything?
This topic was modified 4 months ago 2 times by Mk4User
Posted : 05/11/2025 4:47 pm
iftibashir
(@iftibashir)
RE: Existing MMU Nextruder & MMU3
You should be fine if it's the same extruder that was previously also using the MMU3. Just make sure the filament sensor assembly has been removed - ie, the ball and magnet etc - and the side door has been changed to the MMU3 version.......
Posted : 05/11/2025 6:34 pm
