Does CORE One print well ABS?
zapta
(@zapta)
Coming from the Voron world, ABS is my goto filament. The CORE One specification does mention ABS but I don't see it mentioned much here in the forum, as opposed to let's say PETG, PC, and TPU.
Does the CORE One prints ABS well?
Napsal : 05/05/2025 10:48 pm
RE: Does CORE One print well ABS?
Don't know about ABS but it prints ASA beautifully.
Napsal : 06/05/2025 1:37 am
Barry Robbins
(@barry-robbins)
From the spec sheet......   PLA, PETG, Flex, PVA, PC, PP, CPE, PVB and when using the optional Advanced Filtration System ABS, ASA, HIPS, PA
So, yes ABS is supported.
Napsal : 06/05/2025 2:42 am
Biomech
(@biomech)
It have printed ABS without any issue. But I would recommend to switch to ASA. ABS is the filament of the past which has not advantages over ASA. It's just bit harder to print.
Napsal : 06/05/2025 9:28 am
Kotaztrafee
(@kotaztrafee)
At what speed is the Core One capable of printing ASA?
Napsal : 13/05/2025 3:48 pm
zapta
(@zapta)
Good to know. I will give it a try.
Posted by: @biomech
Napsal : 13/05/2025 4:13 pm
Biomech
(@biomech)
Posted by: @kotaztrafee
With 0.6mm HF nozzle the Prusament ASA filament profile has max volumetric speed set to 34 mm^3/s. That's quite fast. Maybe it's possible to print it even faster, but it may not have good layer bonds if you push it too much.
Napsal : 13/05/2025 8:35 pm
gb160
(@gb160)
Tried ABS-GF on my Core One yesterday and it printed good, I used the generic ABS profile and adjusted temps slightly.
It takes a few minutes to get going as it heats the chamber. Only a smallish part but very nice result, zero warping.
Napsal : 14/05/2025 6:37 am
1 lidem se líbí
zapta
(@zapta)
Posted by: @zapta
I got my CORE One, so far am printing ABS only, the results are excellent, and the chamber temperature is higher than that of my Voron.
Will also try ASA though I am happy with ABS.
EDIT: I use the Prusa build plate that is smooth on both sides and first layer adhesion is very good.
This post was modified před 2 months by zapta
Napsal : 27/07/2025 6:25 pm
1 lidem se líbí
