Core One / Print Temperatures
Page 2 / 2
jan.d.slay
(@jan-d-slay)
RE: Core One / Print Temperatures
You can print the PPA-CF at 290 degrees. If the part needs to deliver maximum mechanical performance, a higher nozzle temperature is always better because it improves layer adhesion. As parts get larger, a stable chamber temperature is recommended.
Posted : 07/05/2026 7:56 pm
Samael
(@samael)
Well yeah i guess higher is better for adhesion, but this thing is indestructable already, with propper orientation it should be super strong even at 290C!
Posted : 08/05/2026 6:22 am
Print_Fandango
(@print_fandango-2)
I just wanted to chime in as I think that the lack of active heating is what is keeping this ecosystem from really standing out.
I own an H2D and Core One Plus. I enjoy the workflow of the prusa more. Print quality is the same on both but I think the Prusa is superior, why, because I know what the printer is doing vs I have zero idea what the automatism of the h2d are compensating for. That and the idea of sending any information, to china, does not sit well with me. They are known thieves and have advanced technologically fast for many reasons, including stealing.
Anything that I consider it to be an original IP, regardless of volume, goes through my prusa always. I do not trust the H2d nor their cloud.
Rant over.
THAT SAID, Prusa, you need to step up your game. Even a BL entry level has internal filtration and active heating. WAKE UP. You dont even have a proper AMS yet and has just release a dry box as if they had invented gun powder. Print quality, repairability and cloud connectivity will not cut it.
The HT90 is also no longer competitive, when better printers suchs as the IDX22 by Vision Miner is now in V4 and continues to grow. It is the go to platform for anybody printing engineering filaments here in North America hands down, the best current bang for your buck.
Nobody will ever buy an HT90 here when you can get the vision miner for just a little more (a few thousand dollars difference yes but this is a minor difference in a commercial graded machine).
Prusa's market, company and vision relies on their filament and overpriced entry level printers and they seem to be gauging their client base with piece meal updates that are behind the times.
The IDX is a great addition but I am not spending 5K to print PLA and PETG when I can do the same for $800 with almost any other machine in the market. The INDX will only shine if it can mix reliably, most other entry level engineering materials relieably, which it can't really. The INDX system will be greeat to have all sorts of different nozzles at hand, different material and have a printer that can print those reliably.
TIME TO WAKE UP PRUSA.
Posted : 08/05/2026 12:33 pm
jan.d.slay
(@jan-d-slay)
Posted by: @samael
Of course. With Siraya Tec PPA-CF and 290 degrees, you'll get great prints.
Posted : 08/05/2026 3:19 pm
James W7TXT
(@james-w7txt)
I'm relatively new to printing engineering materials, but ramping up reasonably quickly, and bumping into some of these issues already. I spend a lot of time manually switching between prototyping filaments & engineering each day. I don't need multi-color, I need two or three toolheads loaded up with, e.g. PLA, PA-CF, and possibly HIPS, ready to go. INDX sounds ideal for this, except it is limited to 300C nozzle temp, which eliminates a couple of materials in the 300-400C range. I recall they said it would be "at least 300C" with people speculating around 330C, not long ago. Will there be a 400C option for INDX? That would be good to know.
With extra insulation, I can easily reach and maintain a 55C chamber temp with the default settings, for the models I've printed so far in this configuration. I don't know how well that would work for max build volume. The temperature will climb higher if you disable chamber temp but I'm not planning on doing that with standard hardware. I think there's a PID loop control for the heat break which uses the print cooling fan above a certain point, but I can't bring myself to look at any more C++ code today.
I'm likely not a typical user, but OTOH I am seeing a lot of people in e.g. automotive communities getting interested in things like PPS-CF after seeing it on social media.
Posted : 08/05/2026 4:32 pm
Posted by: @james-w7txt
I have doubts that the INDX will support a hot end temperature above 300°. Another thing to contend with is the expanded and still passively heated chamber with the INDX attached. I would be curious if it's still possible to get to 55° with this setup. The INDX is not really touted for engineering filaments. There are better setups for that such as the Bambu H2D.
As for PPS-CF, that is currently beyond the capability of the Core One since you need >310° to print it. As for chamber temperature, with the latest firmware 6.5.3 the fans will cut on aggressively after 55°.
I do a lot of PC prints with HIPS as the interface material. Having at least 2 heads and active chamber heating is a must. That's why I purchased an H2D. The Core One I'm keeping for multi-color once I have the INDX in-hand.
Posted : 08/05/2026 8:42 pm
Scottydog
(@scottydog)
Been waiting for this new HT Hotend release but kinda annoying Prusa left us in the dark to when exactly as it was back in December when they mentioned it. I've bought spools of PPA and PPS in anticipation but now being so long I've had to order more PA filament. Sounds like in the posts that PPA is possible at 290 degrees, but due to the application I want to be sure of perfect layer adhesion.
Posted : 14/05/2026 4:14 pm
jan.d.slay
(@jan-d-slay)
Posted by: @scottydog
I’ve been using a NON-Prusa HT nozzle on my C1 since March 2026 and have already printed PPA-CF at 290, 300, 310 and 320 degrees. Unfortunately, I haven’t had the time yet to carry out proper comparative tests to see how good or bad the layer adhesion is at each of these temperatures.
Once I’ve finished installing the chamber heating on my C1, I’ll reprint everything in detail to have some proper comparisons.
Question: Do you intend to print parts that only need to withstand temperature, mechanical stress, or both?
Keep in mind that with PPA-CF, for example, both temperature resistance and mechanical strength increase if you post-cure it.
Posted : 15/05/2026 6:57 am
Posted by: @print_fandango-2
You can always run your H2D in LAN mode, right? (Blocking external traffic in your firewall if you don't trust Bambu to keep things local.)
The IDEX22 is probably not as big in Europe as it may be in the US. It costs more than 50% more than the HT90 here, and while you can buy it from local distributors, I am not sure about their support capabilities.
Posted : 15/05/2026 7:23 am
Scottydog
(@scottydog)
Hey thanks for your reply. So the component is a two stroke engine manifold, I've tested with both PA12 and PA612 and they should tested fine for heat resistance and I have designed to be well capable for strength. My main driver is to be sure to have good longevity resisting the degree of exposure to gasoline fumes combined with the heat it is exposed to. I want to push the safety margin as high as possible, just for piece of mind. I have insulated the Core One with 1" Polyiso foam on the exterior of the sides and top, not front or rear.
Posted by: @jan-d-slay
This post was modified 2 weeks ago by Scottydog
Posted : 15/05/2026 2:34 pm
Page 2 / 2
