6.4.0-RC Firmware for Prusa CORE One
Pagina 13 / 14
RE: 6.4.0-RC Firmware for Prusa CORE One
Posted by: @jurgen-7
Tread carefully... this is an emotional topic for Steve. 😉
IDK. Don't shoot the messenger maybe?
I think the bug before was that if you change the filament and for whatever reason you needed to try again, the bed would move down again. That's why it is supposed to auto home first on a filament change. Unless I'm missing something...
Postato : 28/11/2025 3:31 pm
1 persone hanno apprezzato
ssill2
(@ssill2)
Ok, I just stopped a print because some ninjaflex was under extruding and the the x carriage crashed into the left side when parking the extruder. Back to 6.2.6 for me.
Postato : 28/11/2025 4:33 pm
Posted by: @ssill2
This doesn't seem like an edge case either. Looks like the XL needs more testing.
Postato : 28/11/2025 4:47 pm
gb160
(@gb160)
Posted by: @ssill2
Ive had something similar on Core One.
Would appreciate if someone else with a C1 could test this also... start a print, then cancel it after a couple of layers...does the extruder hit the back corner and skip a few steps where it should normally park ?
I've noticed it do this once on the last RC, now I've just seen it on this latest version. Initially I put it down to some gcode I've been manually editing, now it's just done it on a standard, untouched print from Prusaslicer.
Postato : 28/11/2025 4:53 pm
Neal
 Neal
(@neal-2)
Posted by: @ssill2
I haven't. I need to actually get a fresh set of batteries for my caliper. I've not ever had a problem with PLA requring me to fiddle with extrusion multiplier for it. PETG on the other hand I'm almost never able to use 1.0 and usually end up at like .97 or lower. When I use a new brand of PETG I expect to have to fiddle with the extrusion multiplier. I guess there's a first time for everything.
I am fairly new to 3D printing.   QUESTION:  How do you know when you need to adjust the extrusion multiplier?   Is there a print defect that you look for, or is there some test print people are doing that covers a range of multipliers, similar to a temperature tower?
Cheers,
Neal
Postato : 28/11/2025 4:58 pm
gb160
(@gb160)
Posted by: @neal-2
Posted by: @ssill2
Cheers,
Neal
You can do the Prusa extrusion multiplier test, which is basically an open top, hollow cube printed in vase mode, so the wall is only one perimeter thick.
With standard PS settings the wall should be 0.45mm.
You need high quality calipers, or a micrometer is better. If your walls are above 0.45 you need to decrease the EM, if your walls are under 0.45mm you need to increase your EM.
Having the correct EM means that your parts will have better dimensional accuracy, Top/bottom layers will appear cleaner as there shouldn't be any over or under extrusion.
https://help.prusa3d.com/article/extrusion-multiplier-calibration_2257
Postato : 28/11/2025 5:07 pm
Another way (which is what I do) is install OrcaSlicer and run the built-in calibration tests. You can also download these from Printables and run them through PrusaSlicer but OrcaSlicer makes it easier to set them up.
Postato : 28/11/2025 5:51 pm
Posted by: @gb160
Posted by: @ssill2
Interesting. I recall seeing this after I stopped a print a couple of weeks back but didn't pay attention to it at the time. There is no major difference between the release and RC2 except for some changes around crash recovery which wouldn't be related. So final and RC2 should exhibit the same behavior.  I'll try it out and report back.
Postato : 28/11/2025 5:53 pm
Posted by: @neal-2
Posted by: @ssill2
Cheers,
Neal
@gb160's recommendation is a good test. Another you can try but I find difficult to interpret sometimes is the YOLO test. You can find it in OrcaSlicer with a description of the tests here: https://github.com/OrcaSlicer/OrcaSlicer/wiki/Calibration
Postato : 28/11/2025 5:57 pm
@gb160 I wonder if what you are seeing on the C1 is the same (or related) to what is happening on the XL: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4984
Postato : 28/11/2025 6:43 pm
ssill2
(@ssill2)
so I'm seeing interesting behavior since switching back to 6.2.6 on the XL that I've never seen before. If I abort a print and it moves back to the back left position as normal with whatever toolhead was loaded when I aborted the print, 2 in this case. If I tell it either unload one filament by picking a tool OR I tell it to change filament in all tools and pick extruders 1 - 4, it attempts to home but crashes into parked tool 1! it's able to recover but that's NEW behavior. Sigh. I'm done for today lol
Postato : 28/11/2025 10:30 pm
gb160
(@gb160)
Posted by: @hyiger
Its weird, sounds kinda similar but no idea why other C1 users aren't reporting the same problem...
Postato : 28/11/2025 11:02 pm
Tim
 Tim
(@tim-21)
Utenti
The Prusa PS is at heart a simple 24v LED supply designed to power commercial LED lamp systems. Prusa had the OEM add the power fail catch circuit.
Turning it off remotely via a smart switch or wall switch is acceptable. If a well designed zero crossing smart switch, it's actually easier on the supply than the supply's own power switch.
Postato : 29/11/2025 7:22 am
Steve
(@steve-33)
Posted by: @hyiger
Posted by: @steve-33
Unload/Load filament Z moves. Heads up - in total the bed will still move several times downward for a total of 110 mm from power on if you try to change filament! Depending on where your bed was on power off this action may cause bed to hit the bottom stops!
!t is impossible to move it up manually as Z thinks it's at 0 height and the only way out is to auto Home where real Z zero will get set,
I believe this is by design. This prevents the head front running into a print if it was accidentally left on the bed since the last X,Y,Z position is not saved between power cycles. If you need to manually move the bed, select "Auto Home" then afterwards you can manually move it.
Poorly thought out design if deliberate  -  It can't hit anything left on bed from parked position unless you deliberately choose to do that. All it does is move head from back right corner parked position straight to front right corner, zero X and Y then go into a series of move Z down ignorant of where Z actually is.
Postato : 29/11/2025 7:59 am
Tim
 Tim
(@tim-21)
Utenti
Boy, at the end of the day I may hold off installing 6.4.0 even longer. Waiting until I get my C1+ upgrade kit. Seems even this release is more than buggy.  Though, thinking back to my Mk3 early days, Prusa had a reliable reputation for shipping broken firmware.  I always waited for the next release or two before installing any "upgraded" releases.  Using 1.1.3, wait until 1.1.7 is released before installing 1.1.5 ... that level of consideration.
While they often fixed something in a release, they also broke something. In-house regression testing is NOT in their vocabulary. It appears this dev process hasn't changed.
Postato : 29/11/2025 4:29 pm
mnentwig
(@mnentwig)
 I considered for a second an "unreliable" reputation for shipping broken firmware but it gave me a headache... Well at least while I'm writing this, the printer is printing happily... hey what's that noise ...
EDIT "that noise" was noises of a core one while printing happily... just for the record 😀
Postato : 29/11/2025 4:41 pm
Unless you have an XL, this firmware seems stable enough for a Core One and, so far, fixes issues with nozzle cleaning failures, less aggressive homing and a much more convenient way to tune the belts. I haven't had any failures (BSOD's or otherwise) during a print in the last 2 months.
Postato : 29/11/2025 5:21 pm
ssill2
(@ssill2)
I would concur.  on my CoreOne and my MK4S it seems fine.  Just not on the XL.  I'm curious how stable the 6.5.1 firmware is on the core one L lol.   I've not been checking out that forum yet.
Postato : 29/11/2025 5:25 pm
Kachidoki
(@kachidoki)
I have made several prints mixing two-color PETG with PLA supports on the XL with this firmware. There are some strange behaviors regarding the automatic retraction feature that I have not yet investigated, but printing and parking work well. I have never experienced a print head collision since I got the printer.
Postato : 29/11/2025 7:46 pm
ssill2
(@ssill2)
The head crash I saw on the XL was when canceling prints.  the two color prints I was doing in PLA went perfectly fine.  Printing with ninjaflex, or tpu in general usually requires a couple cancelled prints until I get things dialed in, so it's not an edge case for me at all.
Posted by: @kachidoki
Postato : 30/11/2025 12:58 pm
Pagina 13 / 14
