XY Belt Improperly Installed
Good Day All,
During the initial self test after assembling my recently purchased CoreOne+, I came to the realization that I misguided the XY belts through pulleys and will need to remove and reguide/reroute them before continuing with starting up the unit. I have been unable to find a belt replacement guide as I doubt they need replacing often once properly installed.
I would greatly appreciate if someone can help give me a brief disassembly and belt reguiding process. I'm thinking the plan of attack would be through the extruder assembly.
Thank you.
Opublikowany : 03/06/2026 4:52 pm
