Will Prusa tension meter work?
Just saw another post on belt tension on the C1, which made me wonder...
On my other printers I prefer to use the Prusa tension meter https://www.printables.com/prints/46639 over the app based method, which I found unreliable in my hands. Away from home for a few weeks so can't test it myself, but should the tension meter work with the C1?
Postato : 17/03/2025 11:09 am
Chocki
(@chocki)
It may IF the material properties and slicer settings print it just right to achieve the correct deflection when used.
Personally relying on prints for accurate tension measurement is just asking for variances between prints / printers etc, its one thing using something with a very low friction hinge and using weights, as gravity is close enough around the planet to make this accurate enough, but extruded plastic?. I can print two identical parts with filaments from two different manufacturers and will get big differences. Even different batches from the same manufacturer can vary.
Your best bet is using prusament and see what other people who use the exact same model and slicer setting get, ie they know their frequency, they print the same tensioner gauge using the same prusament filament (inc colour) type, and report if it shows an accurate deflection.
If nearly everyone says it works. showing the correct deflection, then you have a high probability of it working correctly.
Questo post è stato modificato 1 year fa da Chocki
Postato : 17/03/2025 3:52 pm
Chocki
(@chocki)
RE: Will Prusa tension meter work?
I have checked the app measurement against a reliable belt tension frequency meter and it actually does read the correct frequency, although my phone a pixel 9! is a little deaf and struggles to hear the belts using the built in mic.
I am considering buying a bluetooth over ear headset anyway, so when I do I will give this a try and see if it is any better.
Postato : 17/03/2025 3:57 pm
I know. As I said, I've been using the printer tension meter for many years with Mk3, Mk4, Minis, I was just specifically curious if it worked with the c1 as it has a different belt system.
Postato : 17/03/2025 5:01 pm
cryptomilk
(@cryptomilk)
The Gates Carbon Drive Mobile App in motorcycle mode works just fine: https://www.gatescarbondrive.com/products/tools
Postato : 17/03/2025 8:02 pm
Butters
(@butters)
How do you use the app, I don't see it on their site ?
Posted by: @cryptomilk
Postato : 11/11/2025 1:40 pm
Posted by: @butters
If you have an iPhone then you can find it on the App Store. It's easier to install the 6.4.0-RC firmware and use the new belt tuner.
Postato : 17/11/2025 4:44 pm
