Upgrading from MK4S + MMU3 to CoreOne
lschelvis
(@lschelvis)
I currently have a MK4S with the MMU3. This week I will receive the upgrade kit to the CoreONE. I also ordered the MMU3 enclosed kit to be able to place my MMU3 on the CoreONE. Can I just place the nextruder will all upgraded components in the CoreONE or am I missing something?
Napsal : 30/08/2025 2:52 pm
grayin
(@grayin)
RE: Upgrading from MK4S + MMU3 to CoreOne
I did this same conversion last week. Kept all the MMU3 parts on the nextruder during the conversion. I had the MMU connected and a flash drive with the latest core one firmware inserted when I finished the conversion and turned on the core one for the first time. It asked if I wanted to flash the new version and after that it started up as a core one. I did go in the menus and make sure the MMU was turned on and then had to run the calibrations myself (it didn't prompt like a new machine). Only weird thing was it changed the nozzle setting to a high flow nozzle. Had to change that back to match my regular nozzle and then everything worked fine after the usual messing with belt tension etc..  Good luck.
Napsal : 30/08/2025 8:22 pm
