The chamber fan is not spinning
Has anyone faced this problem before?
After assembling the Core One kit, I performed calibrations and then fan tests. After a while, a message popped up that the chamber fan is not spinning. But... the fans are spinning, they also react to speed changes. After starting the print they also regulate the temperature in the chamber. They are connected correctly, the green LEDs on the xBuddy extension are on.
How to convince the printer that the fans are fine?
This topic was modified 7 months temu by 3Direction
Opublikowany : 06/08/2025 5:22 am
Topic starter
answered:
RE: The chamber fan is not spinning
So it's solved. I ordered a new fan, installed it and everything is OK. It was simply defective. Its speed sensor didn't work.
Opublikowany : 07/08/2025 3:00 pm
