Start print before chamber is heated to nominal temperature
Hello,
i've upgrades my MK4S this weekend to a Core One. Worked well - no issues so far.
But i've a question to the chamber heat function. I print PETG with Prusament, which tries to heat the chamber to 35° before the print starts. I can skip this step by pushing a button on the touchscreen.
For short prints, this is not needed (in my opinion - worked with MK4s without the chamber with no problems). So i thought, i could change the settings for this in the filament profile.
There's under "Filament" the Point "Chamber", set to "Nominal" and 35°. Minimal was set to 0°.
The help-text of this values:
- Nominal: Required chamber temperature for the print
- Minimal: Minimal chamber temperature that the printer waits for before the print starts. This allows to start the print before the nominal chamber temperature is reached.
So i changed the "Minimal" temp to 25° (actual room temperature). I thought, the printer would wait till 25° are reached, then starts the print. If 35° are reached, the chamber fans starts spinning.
But that's not the case; i still have to skip the "absorbing heat"-Message on the Touchscreen, before the print starts.
Did i missunderstood something, or is there another way to reach what i want to do?
Thanks in advance,
Bastian
You did everything correctly regarding minimum and nominal chamber temperature. Absorbing heat is not just waiting for temperatures, it's meant to get the whole printer up to "working-temperature" to not cause slight inaccuracies.
However, I'm totally with you: it's way too long in most cases! It's a simple G-Code command and I think it's an algorithm in the firmware for the duration..
You can disable the G-Code command in the Start G-Code though.
