(solved) MMU layer shift from nozzle getting stuck in wipe tower
mnentwig
(@mnentwig)
For discussion (and "note to self" if running into it again):
I'm printing ASA at 275 degrees, which is the upper limit printed on the spools, in other words quite far above the melting point (/glass transition temperature).
When the MMU changes filament, it hesitates several seconds over the wipe tower with minimum (if any) gap. This (possibly in combination with some material dripping from the nozzle) results in an uneven wipe tower surface that eventually catches the nozzle, leading to layer shift. Settings may work on testprints with small objects but fail when the printing time per layer goes up.
The solution was to insert a custom "Tool change" G-code (Printers/custom G-code/Tool change G-code):
G1 Z+10 F10000; avoid melting into wipe tower (-mn)
This raises the head by 1 cm for the color change.
Publié : 22/11/2025 6:48 pm
mhohensee
(@mhohensee)
Membre
RE: (solved) MMU layer shift from nozzle getting stuck in wipe tower
I found that this helped me as well, thanks!  The only issue I subsequently discovered is that the print head is only lifting to Z=10mm, not a relative lift of +10 on Z.  This whole thing works as well as it does because the printer is set to absolute, rather than relative coordinates (so that it goes back to what it was doing after the filament change), but will lead to crashes for wipe towers taller than 10mm.  I tried wrapping this with a switch to relative coordinates:
G91;G1 Z+10 F10000;G90
But for some reason this causes my print to fail to even make the base of the wipe tower properly.  Perhaps there's some important value getting wiped out in the G91/G90 transition.  Have you any thoughts on this?
Publié : 08/12/2025 3:55 pm
mhohensee
(@mhohensee)
Membre
Posted by: @margie129palmer
Hello!
Printing ASA at 275°C caused nozzle drag on the wipe tower during MMU filament changes, leading to layer shifts. The fix was adding a custom tool‑change G‑code (G1 Z+10 F10000) to lift the nozzle 1 cm during color swaps, preventing it from melting into or catching on the tower.
Did you ever print anything that required a wipe tower more than 10mm high?  The problem I ran into is that putting that command into the tool change gcode only moved my extruder to z=10mm, and started crashing into the wipe tower once the tower exceeded 10mm.  Was this not a problem for you?
Publié : 09/12/2025 3:20 pm
1 personnes ont aimé
k1mu
 k1mu
(@k1mu)
Posted by: @mhohensee
Hello!
@margie129palmer is a scammer, notice the odd link in their sig? And that they just repeated something someone else said?This kind of pattern has been seen a bunch on the forum - scammers with <name><number><name> as their username with no valid content.Ignore or report.
Publié : 15/12/2025 4:15 pm
mnentwig
(@mnentwig)
I'm afraid you're correct. And yes, I usually run 0.25 mm nozzle and sparse wipe tower with (largely) horizontal color layering to minimize tool changes. So 10 mm wipe tower would be a lot.
It seems it would require a change to relative mode, offset and back to absolute mode. Now I recall there were examples that did just that but didn't work for me. The "Z+10" looked like a relative movement in a place where one was expected but now it turns out it's not.
Publié : 15/12/2025 5:46 pm
Finalfill
(@finalfill)
Temporarily switching to relative positioning seems to interrupt extrusion afterwards. I found that it's better to stick with absolute positioning. This works like a dream:
G1 Z{min(layer_z+15,max_print_height)} F3000 ; Lift Z by 15mm to avoid formation of blob on tower.
Min function ensures that max print height is not exceeded (unsure if needed, but thought it was safer to include just in case).
Publié : 06/02/2026 4:31 pm
2 personnes ont aimé
mnentwig
(@mnentwig)
Awesome, thanks! And yes, I've noticed the same that extrusion stops when I try relative positioning, possibly leaving zero gap between nozzle and print head for the material to pass through (theory)
Publié : 06/02/2026 8:02 pm
actionandpositivity
(@actionandpositivity)
This code appears to error now when slicing Printers->Custom G-Code-> Start G-Code -> insert at end of everything there. Likely I am doing something wrong
Posted by: @finalfill
Ce message a été modifié il y a 2 months 2 fois par actionandpositivity
Publié : 07/03/2026 11:50 pm
mnentwig
(@mnentwig)
Posted by: @actionandpositivity
it needs to go into Toolchange G-code not "Startup" (maybe revisit what it does - it's supposed to lift the nozzle for every tool change).
I use the short version G1 Z{layer_z+15} F5000 in every print.
"layer_z" is toolchange-section specific. It does not exist at startup => error.
Note, this doesn't help if the filament is dripping and a "blob tower" forms dripping on the wipe tower. In that case add "Y0 X250" to the line and put a fingerprint in the front right corner on the print bed so any large blob gets knocked over (2nd line of defence, shouldn't happen in the first place, e.g. lower temperature or use more expensive / drier filament)
Publié : 08/03/2026 7:39 am
