Screw won't grip
Clem
 Clem
(@clem-3)
Screw won't grip
Hello,
I'm currently assembling the Core One+.I'm having the problem that in step 29 (29. Installing the motor mount right) the M3x6 screw that secures the motor mount won't grip. It just spins freely.
https://help.prusa3d.com/guide/5-corexy-assembly_982276#990374
Is this a problem?
I also can't find a matching replacement part. I have version E4, but in the shop I only find version E3.
Can I safely order that? Thanks!
Is this a problem?
I can't find a matching replacement part. I have version E4, but in the shop I only find version E3. Can I safely order that? Thanks!
Posted : 31/01/2026 10:10 pm
Etadriver
(@etadriver)
Hello, i think that screw is only for hold in place by building the next steps. There comes 4 more screws from the motor. So it is posible that the next steps seems a little bit difficult to hold the part in place.
You can contact the support they send you a spare part, and yes you can buy the E3 spare part, they send you the newest one, its only the discription that is not actual.
Sorry for bad english, without google transl.
This post was modified 11 hours ago by Etadriver
Posted : 01/02/2026 2:34 pm
RE: Screw won't grip
Posted by: @clem-3
Hello,
Is this a problem?
Is this a problem?
"E" means the part was made by Prusa and "R" means the part was self-printed. The number afterwards is the version number of the part. All of the part STL's are available on Printables. If you have a spare printer or have a friend with a printer, you can print these parts yourself.
Posted : 01/02/2026 3:50 pm
