screw loose
Gerf Derp
(@gerf-derp)
screw loose
Technically a bolt, but still.. When setting up my assembled Core ONE I noticed a hexcap bolt wedged between the bed and the side wall. When I tried to get it out it fell and rolled under the side panel.
I did a quick scan of the parts inside but I couldn't see from where it might be missing.
Any particular place I should check before trying to run it? Should I just pretend like it was a spare left behind?
Respondido : 06/04/2025 12:24 am
1 les gusta
boB
 boB
(@bob-3)
RE: screw loose
I found a hex nut in the bottom of mine, not able to find where it goes.  Maybe it's yours?  😉
Respondido : 06/04/2025 7:05 pm
2 les gusta
Kachidoki
(@kachidoki)
RE: screw loose
On mine I found the chamber fan screws to be loose. One screw and the temperature sensor zip-tie were rubbing against the belts.
Respondido : 07/04/2025 7:16 pm
1 les gusta
