Prusa Core One - VIDEO BUILD GUIDE
Página 3 / 3
Fred
 Fred
(@fred-4)
RE: Prusa Core One - VIDEO BUILD GUIDE
Thanks for the guide. I watch it several times before I received my kit. It was a great reference during my build.
Thanks again,
Fred
Respondido : 04/07/2025 4:57 pm
iftibashir
(@iftibashir)
Glad it helped!
Respondido : 14/07/2025 9:59 am
aln.perez
(@aln-perez)
Very good videos. I think the power cable management is the issue; normally they run through the frame...
Power cable
MK3S + MMU2 migrée vers une MK4 +MMU3 , puis vers MK4S MMU3, puis upgrade vers Core One, Elegoo Mars, bricole sur Home assistant, arduino, 8266, Esp32, kicad, Freecad et Fusion 360
Respondido : 16/07/2025 3:21 pm
iftibashir
(@iftibashir)
Not seen that image before where the cables run through the actual rear panel? Prusa instruct to use the cable cover just above......
Posted by: @aln-perez
Power cable
Respondido : 16/07/2025 9:28 pm
iftibashir
(@iftibashir)
Bump....to help more people build their Core One Kit!
Respondido : 26/07/2025 7:48 pm
aln.perez
(@aln-perez)
Thank you very much, your videos helped me a lot to upgrade my M4KS (similar to a Core One Kit). It was very well explained, and my Core One worked perfectly as soon as I turned it on. Zero problems, I upgraded to the latest firmware 6.3.5 and the VFA has decreased a lot since 6.3.3.
Respondido : 26/07/2025 7:57 pm
1 les gusta
iftibashir
(@iftibashir)
Another happy viewer 😉
Good to hear all went well, and good to see Prusa are [slowly] addressing and fixing issues!
Respondido : 26/07/2025 8:04 pm
1 les gusta
iftibashir
(@iftibashir)
bump....
Respondido : 10/08/2025 10:17 pm
iftibashir
(@iftibashir)
bump....
Respondido : 22/09/2025 2:14 pm
iftibashir
(@iftibashir)
Getting this up there to help more builders!
Respondido : 04/11/2025 3:05 pm
iftibashir
(@iftibashir)
Respondido : 07/01/2026 9:53 am
Conrad
(@conrad-2)
That's a brilliant and, no doubt, a massively time-consuming effort! I only watched a little, having already built my Core One, but everything is well staged and very clear. There are a couple things I'd suggest, based on various posts here and other platforms. Several parts should be carefully checked before assembly, especially the brackets holding the X-axis rail. They should be checked with a square, so any later bending is kept to a minimum. Next, and it was missed in the X-Y assembly section, it's critical that the belt tensioner screws get lubricated with the Prusa grease, lest they wear and/or gall and seize. Knowing what I know now, I probably would have lubed the threads of any screws going into the square stainless-steel nuts and the self-locking hex nuts. I know there's one in my printer that I hope never to have to take apart, as it will almost certainly destroy its mating plastic part.
Respondido : 08/01/2026 12:36 am
2 les gusta
Página 3 / 3
