Problém s kalibrací – 3. test osy Y (Prusa CORE One, FW 6.3.4+10511)
[Resuelto] Problém s kalibrací – 3. test osy Y (Prusa CORE One, FW 6.3.4+10511)
padik
(@padik)
Miembro
Ahoj, potřebuji poradit s kalibrací u tiskárny Prusa CORE One. Kalibrační průvodce mi opakovaně končí chybou na 3. testu osy Y.
Tiskárna: Prusa CORE One Firmware: 6.3.4+10511
Projevy
skončí chybou na 3. kroku osy Y.
Všechny ostatní testy proběhly bez problémů.
Normální tisk funguje bez potíží.
Při ručním pohybu necítím žádné zadrhávání.
Rozsahy pohybu:
vosa Y: -19 až 221 mm
vosa X: -2 až 249 mm
Řemen Y je podle kontroly správně napnutý.
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/9c3e4095-img_0840.mp4
Calibration problem – 3rd Y-axis test (Prusa CORE One, FW 6.3.4+10511)
Hi, I need help with calibration on my Prusa CORE One printer. The calibration wizard repeatedly ends with an error on the 3rd Y-axis test.
Printer: Prusa CORE One Firmware: 6.3.4+10511
Symptoms
ends with an error on the 3rd step of the Y-axis.
All other tests were successful.
Normal printing works without problems.
I don't feel any stutter when moving manually.
Movement ranges:
Y-axis: -19 to 221 mm
X-axis: -2 to 249 mm
According to the inspection, the Y-belt is correctly tensioned.
Este debate ha sido modificado el hace 1 month por padik
Respondido : 17/08/2025 9:31 am
RE: Problém s kalibrací – 3. test osy Y (Prusa CORE One, FW 6.3.4+10511)
Please translate your post to English before you publish it in the English forum, using Google Translate or another service you like. It's much easier for you to do it once, than for every single reader (who does not happen to speak your language) to do it on their own.
Respondido : 17/08/2025 6:42 pm
padik
(@padik)
Miembro
ok
Respondido : 17/08/2025 8:22 pm
My understanding is that it's can be caused by 2 possible issues:
  1. The gantry is not square. This happened to me after tensioning the belts incorrectly and slightly bending the gantry. Once I straightened it, the Y calibration issues went away
  2. In some cases, the filter sensor cable gets in the way and prevents a successful Y calibration
Respondido : 18/08/2025 7:58 am
