[Resuelto] Printer will not extrude any filament
mbarclay36
(@mbarclay36)
Miembro
I just finished building my core one kit and passed all the calibrations. I started my first print with the PLA that came with the printer, but no filament came out. This is what I've done to try and troubleshoot:
  • Tried unloading and re-loading the filament multiple times. Every time it got to the step where it asks if it's the correct color, I don't see anything and no matter how many times I click "purge more" nothing comes out.
  • Tried to heat up the frontend and manually extrude. Nothing came out.
  • Tried re-running the gearbox alignment calibration multiple times
  • I noticed this whole time that the filament was never moving when I was extruding. I wondered if the gears were moving at all. I tried loading in some filament, opening the idler slightly so I could see the gears and extruding. The gears did not move at all. I tried unplugging and re-plugging the extruder motor but that did not help.
At this point, I'm not sure what to do. When I put the gearbox together there was a bit of resistance when spinning it, but looking at the comments other people had that too. Any help would be greatly appreciated!
Respondido : 25/06/2025 4:58 pm
mbarclay36
(@mbarclay36)
Miembro
RE: Printer will not extrude any filament
Solved it, I noticed that there was a newer version of firmware than the one that came on the usb. I figured I needed to update in anyway so I did that and now it's working.
Respondido : 25/06/2025 7:56 pm
For first build issues it's always best to contact Prusa Support via chat.
You will need your machine's serial number and possibly your order number.
Log into your Prusa account; on most browsers chat is at bottom right.
Respondido : 25/06/2025 9:20 pm
1 les gusta
