Print head stuck to print and now nozzle is loose
I had a print fail and it ended up being attached to the buildplate and the nozzle by the print. When I tried to head the nozzle up to remove it from the stuck printer it tried to move the nozzle to the home position and I heard some not nice noises.
I tried to print again and it fails and the nozzle seems really loose. I've been dreading taking it apart, but is there anything specific I should be looking for and seeing what the issue could be?
Posted : 08/11/2025 5:41 pm
RE: Print head stuck to print and now nozzle is loose
How is the nozzle inserting into the heat block and how is the heat block positioned into the nextruder heatsink? Also, are the thumbscrews tightened enough? Could you attach a photo of your nozzle and hot end?
Posted : 08/11/2025 9:29 pm
