Print fan cooling duct scraping on bed cable cover when using the Satin print sheet.
Page 2 / 2
gb160
(@gb160)
Posted by: @george-4
First change that screw for an extra black torx one so that the cover sits correctly, and i guess contact support to see what happens. my satin also has a mark there, but i guess its not that bad and i can just use the other side. I know, i shouldn't have to settle for this.
Just following up on this, I contacted support a few minutes ago, sent a picture of my damaged sheet, linked this thread and the reddit thread, new Satin Sheet on its way today no questions asked.
Edit, probably not being shipped today , just checked and they're out of stock 😂
Posted : 29/04/2025 8:37 am
George
(@george-4)
RE: Print fan cooling duct scraping on bed cable cover when using the Satin print sheet.
I got a different issue with the satin plate. i printed a full bed layer, and the paint came off on the print 😂
Posted : 29/04/2025 8:44 am
gb160
(@gb160)
😂 How ?
Did you have the Core one satin sheet, or the standard Prusa one ?
Posted : 29/04/2025 8:45 am
George
(@george-4)
Posted by: @gb160
😂 How ?
Standard prusa one. When i placed the order i couldn't add a core one satin one.
Posted : 29/04/2025 8:47 am
Kyosuke_14
(@kyosuke_14)
I see that they already change the screw on the assembly guide. They also change the two other screw next to
Posted : 30/04/2025 1:20 pm
gb160
(@gb160)
Posted by: @kyosuke_14
I would've thought they'd have sent an email out to anyone who has received the kit up until now. Especially considering it can damage the Satin sheet... not sure about the other sheets.
Posted : 30/04/2025 1:38 pm
AvariCe
(@avarice)
Posted by: @gb160
😂 How ?
I know it's a late response, but I was talking to support earlier today and they told me that the standard mk4 sheet is practically the same between the core one and the mk4s. The difference is that if you use the the mk4s sheet on the core one, the core one will print over letters on the sheet (like you discovered) because on the core one the print area is a little bigger on the Y dimension.
Posted : 02/05/2025 9:27 pm
lancer enkor
(@lancer-enkor)
It is disappointing, I found this error after failed print. They don't even change version of instruction or put it in changelog.
Posted by: @gb160
Posted : 12/05/2025 2:06 pm
iftibashir
(@iftibashir)
The two screws holding the power terminals were already using the round head screws to start with. They just changed the middle one from a cap head to a round head.
Posted : 12/05/2025 7:25 pm
Page 2 / 2
