No Filament Extruded and Heat Bed Issues
Page 1 / 2
Butters
(@butters)
I'm trying to print using the filament given in the CoreOne kit but nothing comes out of the Obxidian nozzle ? As well my heat bed doesn't go back to it's rest position, it's stuck in the middle ?
Best Answer by hyiger:
Posted by: @butters
It was the spring screws on the idler a little too tight.
Right... Those are the same screws I was referring to in the photo. It's also why I wanted you to take a photo. It would have saved time.
Hopefully no more issues. Just make sure you check the belt tension from time to time.
Publié : 04/12/2025 2:20 pm
RE: No Filament Extruded and Heat Bed Issues
OK Butters. Before I answer your question you have to answer one of mine. So X, Y, Z and homing calibration now consistently pass? Answer this first and I will help you. You never responded on the HOMING thread whether you were successful or not. Some of us spent a lot of time helping you.
Publié : 04/12/2025 2:48 pm
Butters
(@butters)
I plan on giving a explanation on that for anyone in that situation; but in short, yes HOMING passed.
Posted by: @hyiger
Publié : 04/12/2025 2:49 pm
Posted by: @butters
Well, it's more to acknowledge to the rest of us that the help we gave you worked; that you appreciate the time and effort we provided to help fix your issue. Also, provide information on what you did that fixed your issue for the benefit of others who might run into similar problems in the future.
Do that first and I will help you with this issue.
Publié : 04/12/2025 2:59 pm
Butters
(@butters)
I should have noted, that the explanation will come soon. If I can today, otherwise in the coming days.
Posted by: @hyiger
Posted by: @butters
Publié : 04/12/2025 3:01 pm
Posted by: @butters
OK, as soon as you do that I will help you with this problem. But not until then.
Publié : 04/12/2025 3:09 pm
OK, butters. I see you responded (sort of) on the HOMING thread.
So let's begin...
  1. Did all of the calibration tests pass? Does every test have a green check mark?
  2. When you insert the filament into the Nextruder, do you feel it pulling on the filament to load it into the nozzle? If not, perhaps you are not inserting it far enough.
  3. When it is purging the filament, do you see anything come out of the Nextruder?
  4. Did you confirm that the idler level is locked and that the idler tension screws are correct set?
Publié : 04/12/2025 5:35 pm
Butters
(@butters)
All the Calibration tests passed, I tried to print one of the objects on the USB key, although no filament was coming out so it was essentially printing nothing but an imaginary object.
I do feel the filament being pulled into the nozzle; remember the nozzle is brand new, never used. I don't see anything coming out of the Nextruder, I tried a test whereas you increase the temps for the nozzle and see if some filament comes out; nothing this is on Prusa web site.
Posted by: @hyiger
So let's begin...
Publié : 04/12/2025 5:38 pm
Posted by: @butters
OK. When you load filament for the first time, the very first thing it does is purge the filament. You should see a long string of melted filament coming out of the nozzle for (I think) around 10 seconds. Then is asks you "Is the color correct". Then you are supposed to select "Yes" or "Purge More" or "Retry". So when it's at the purging stage what is happening? Until you get a proper purge you will not be able to print anything.
Also, during the purging process touch the filament where it is entering the Bowden tube. Do you feel it getting pulled into the tube?
Publié : 04/12/2025 5:44 pm
Butters
(@butters)
I've purged multiple times, I feel it getting tugged at into the tub. Although, nothing comes out of the nozzle, it sounds as if something is trying too but nothing.
Posted by: @hyiger
Posted by: @butters
Publié : 04/12/2025 6:05 pm
Ok.
  1. Is the nozzle getting hot?
  2. Open the idler lever and look inside do you see filament pushed through? I've attached a photo to show you what is looks like, I've used orange filament so you can see it clearly. Please take a similar image so I can see what it looks like.
Publié : 04/12/2025 6:46 pm
Butters
(@butters)
I see the filament loaded through.
Posted by: @hyiger
Ok.
Publié : 04/12/2025 6:49 pm
Butters
(@butters)
The nozzle is hot, I now have a little temp burn mark on the finger.
Publié : 04/12/2025 6:52 pm
Posted by: @butters
Think of that as a right of passage.
Posted by: @butters
OK. Can you check that the idler tension screws are correctly tightened. Can you take a photo like this. The ends of the screws should be flush with the idler nut. I suspect it's not tight enough and it's not grabbing the filament.
Publié : 04/12/2025 7:23 pm
Butters
(@butters)
I tightened the idler screws, and did another nozzle test, nothing continues to extract.
Posted by: @hyiger
Posted by: @butters
Posted by: @butters
Publié : 04/12/2025 8:10 pm
What is it doing? Is it making a loud clicking sound? Also try a different piece of filament.
When you say you "did another nozzle test" what do you mean. Please describe what you tested and how? At this point you should only be trying to purge the filament.
Now before we continue, I would like you to take a photo from the same angle as mine of the idler screws. Once I see the photo, then I will continue to help you.
Publié : 04/12/2025 8:29 pm
Butters
(@butters)
I have successfully fixed the filament extrude issue which was related to some screws on the idler but not particularly the ones you mention @hyiger. Here is my first print the results are better then I expected from this printer.
Printed Boat
As well my CoreOne+ upgrade as shipped, it's for the stickers. 😀
Ce message a été modifié il y a 5 months par Butters
Publié : 05/12/2025 2:29 pm
Posted by: @butters
Printed Boat
Good to hear that butters! Which screws are you referring to? The ones that attach the cover to the planetary gear box? Were they too tight causing the gears to bind?
Publié : 05/12/2025 2:33 pm
Butters
(@butters)
Posted by: @hyiger
Posted by: @butters
Printed Boat
Publié : 05/12/2025 2:43 pm
Posted by: @butters
Publié : 05/12/2025 2:56 pm
1 personnes ont aimé
Page 1 / 2
