Missing belt tensioner right
YamiGhor
(@yamighor)
Hello everyone,
I'm assembling the kit for Prusa Core One+ and on Chapter 5 part 22  it's missing Belt tensioner right I have two belt tensioner left and I searched on all boxes.
What I have to do? Can I print that part with my other printer? This are the parts? https://www.printables.com/model/1167816-core-one-printable-parts/files#preview.file.o5EMR
It's my first Prusa and have everything on the table T_T
This topic was modified 1 day ago by YamiGhor
Posted : 06/12/2025 1:40 am
RE: Missing belt tensioner right
Just print a temporary part from the link above CORE One printable parts. It will be exactly the same as the one that was missing. Do not print it with PLA. Ideally PC-CF but ASA or PETG (temporarily) should do. Also, make sure not to forget to lubricate the screws. If you happen to have M3 brass inserts then there is a better alternative: CORE One belt-tensioner-pulley to take a threaded insert instead of the original square nut If not then just print the original to get you up and running.
Posted : 06/12/2025 3:37 pm
