Lateral shifts during printing
6SF5
 6SF5
(@6sf5)
I started a print, twice, and had on both prints this type of shifts.
What is the cause and what to correct....retraction ?
Postato : 17/05/2025 10:55 am
RE: Lateral shifts during printing
You have an inherently awkward shape to print.  The shallow rising curve is very likely to warp upwards causing minor head-crashes so slowing down the print and checking the following settings should help:
Avoid crossing curled overhangs
and
Avoid crossing perimeters
You should also dry your filament to reduce stringing and blobbing; they probably aren't the cause in this case but they're not helping.
If problems persist show us the sides of a print so that we can look for signs of bad belt tension.
Postato : 18/05/2025 6:20 am
1 persone hanno apprezzato
6SF5
 6SF5
(@6sf5)
Printed in ABS, after different tries I solved by printing inclinated. Perfect result !
Postato : 19/05/2025 12:51 am
