RE: Lateral shifts during printing
You have an inherently awkward shape to print. The shallow rising curve is very likely to warp upwards causing minor head-crashes so slowing down the print and checking the following settings should help:
Avoid crossing curled overhangs
and
Avoid crossing perimeters
You should also dry your filament to reduce stringing and blobbing; they probably aren't the cause in this case but they're not helping.
If problems persist show us the sides of a print so that we can look for signs of bad belt tension.
Respondido : 18/05/2025 6:20 am
1 les gusta
